    Face to cam script for PDF3D
    4 Posts 2 Posters 1.2k Views 2 Watching
    • juan974J
      juan974
      hi all,
      i m starting to use javascript for PDF3D, here is an example :
      tree always face, acrobat 8.1 minimum
      the goal is to clone sketchup with "face to camera" function.
      but as you can see in the attached PDF, each time the camera angle is around 0, the tree rotation of +180° if cam angle is positive and -180° if cam angle is negative.
      here is the code :
      runtime.setCurrentTool(runtime.TOOL_NAME_SPIN);
      myMouseHandlerPositonCam= new MouseEventHandler();
      myMouseHandlerPositonCam.onMouseMove= true;
      myMouseHandlerPositonCam.onEvent= function( event )
      var VecteurCameraXPositonCam =((scene.cameras.getByIndex(0).targetPosition.x)-(scene.cameras.getBy Index(0).position.x));
      var VecteurCameraYPositonCam =((scene.cameras.getByIndex(0).targetPosition.y)-(scene.cameras.getBy Index(0).position.y));
      var VecteurCameraZPositonCam =((scene.cameras.getByIndex(0).targetPosition.z)-(scene.cameras.getBy Index(0).position.z));
      AngleCamPositonCam=Math.atan(VecteurCameraYPositonCam/VecteurCameraXPositonCam);
      for (var i=0; i < scene.meshes.count; i++)
      var result = scene.meshes.getByIndex(i).name.indexOf("tree");
      if (result>-1)
                m1 = new Matrix4x4().rotateAboutZ(AngleCamPositonCam+Math.PI/2)
                scene.meshes.getByIndex(i).transform.set(m1);
                scene.meshes.getByIndex(i).renderMode = ("solid");
      runtime.addEventHandler( myMouseHandlerPositonCam );
      i tried to add a condition :
      if AngleCam > 0
      then m1 = new Matrix4x4().rotateAboutZ(AngleCamPositonCam+Math.PI/2)
      else m1 = new Matrix4x4().rotateAboutZ(AngleCamPositonCam-Math.PI/2)
      but it doesn t work...
      any ideas?
      juan974 (Réunion island)
      website : http://sketchucation.com/click.php?url=http://www.tarn.us
      • Dan RathbunD
        Dan Rathbun
        bbCodes use square brackets [ code ] and [ /code ] not < code >
        I'm not here much anymore.
        • juan974J
          juan974
          i'm a newbie in programming ...
          • juan974J
            juan974
            finally the problem was tan(alpha)=tan(alpha+180°)
            here the result... 😍
