[Plugin] jsMoveTool [updated to v2014]
Did you press enter before using the arrow keys?
I just tried installing on a fresh version of SU 2018 and it worked just fine here.
Could it perhaps be a conflict with some of your other plugins? -
hi pixero
I'm pressing enter after i set the distance.
The plugin as worked all the time on other computers, but not on this one.
Are you also using . instead of , ? i have never had an installation before where i need to use . as a decimal separator.
Jorgensen -
Hi Pixero
I searched the jsmovetool.rb, deleted two instances, and installed via extension store.
Now it works
Jorgensen
Great!
Thank you so much for this, what a boon! I don't know why this isn't built into Sketchup as a default.
Again, thank you so much, it really helps!
Register LoginAdvertisement
