    Page UpDate problems
    5 Posts 4 Posters 432 Views 4 Watching
    • K
      ktkoh
      My script creates a new page and adds several views of a component then finishes with
      Sketchup.active_model.active_view.camera.perspective = false
              Sketchup.send_action "viewFront;"
              Sketchup.send_action "viewZoomExtents;"
              Sketchup.send_action "pageUpdate;"
      However it often does not update the page view. If I select the page then the view shows as expected so the actions were applied except for the final update of the view.
      I had seen a comment here about how to fix this and had copied the info but now that I want to use it it's not where I can find it. Any Suggestions??
      Keith
      • ppoublanP
        ppoublan
        Just in case, (think you already done but...) did you try
        Sketchup.active_model.active_view.refresh ?
        Yours
        Pascal
        • tt_suT
          tt_su
          Have you tried using the methods on the View and Camera object directly instead of the send_actions?
          send_actions isn't the best to use ... personally I wish they weren't there. There should be proper API methods for them instead.
          • K
            ktkoh
            The view refresh worked. Thanks.
            Keith
            • Dan RathbunD
              Dan Rathbun
              As I recall from the last build cycle (2013,) the Sketchup::Page and Sketchup::Pages classes had issues filed on them regarding updates not working correctly. (As well as a bunch of feature addtions, by myself.)
              I'm not here much anymore.
