    SU2014 - can't load EventRelay.dll
    5 Posts 3 Posters 1.1k Views 3 Watching
      sergey2402
      I use the plugin ERRightMousePan.rb long time.
      In order for it to work you need to use EventRelay.dll.
      But I foung it can't work in Sketchup 2014.
      Does anyone know what to do?
      • Dan RathbunD Offline
        Dan Rathbun
        It would need to be re-compiled against the Ruby 2.0.0 source, I think.
        I'm not here much anymore.
          sergey2402
          Thank you very much for the answer, but I really did not understand.
            Dan Rathbun
            It needs to be re-built for SketchUp 2014.
            And I thought I heard (in the Ruby Installer forum,) that Ruby 2.x require no longer supports DLL files.
            But was told they could be renamed with SO extension.
            I tried the renaming but it does not work.
              Anton_S
              SU2014 supports StandardLibrary, which supports fiddle. You could use it to export DLL functions.
