    [Plugin] GKWare Door Maker
    46 Posts 10 Posters 9.4k Views 10 Watching
    • G Offline
      Garry K
      "GKWare Door Maker" is my first plugin to go into the PluginStore.
      Page not found | CabMaker32Page not found – CabMaker32
      (cabmaker32.com)
      Please give feedback on language support
      Thanks to unclebim for his cleaning up of the images. Available from his post lower down on this page. The images are smaller and now are seamless.
      Thanks to Igor Sepelev for his help on the Russian translation.
      Thanks to XIAOLONG for providing the Chinese (Simplified) translation - zh_cn.lang
      Thanks to Oxer for providing the Spanish translation - es.lang
      Thanks to Gianni for providing the Italian translation - it.lang
      Thanks to marsahl for providing the German translation - ge.lang
      I have used online translator for French and Chinese (traditional). These 2 translations are in need of help. Hopefully they are only funny in spots and not rude.
      Please open up en.lang as a template in Notepad++ and save as in language that you are translating. Thanks everyone for their technical support.
      To test a translation you need to edit 1 line in defaults.txt. This example forces Door Maker to use french.
      language=fr
      Next version To do list
      Wish List
      1. Pick face(s), bring up Door Maker, configure and convert faces to door or drawer.
        Version 1.0.22
      2. If you drag with "one click" there was a line which was confusing. Fixed.
      3. The stile profile is now a separate moulding and no longer part of the panel.
        This is so that glass and mirror type doors can have the same look.
      4. Added 4 new door shapes for Pro version.
      5. Added 1 new door style for Pro version.
      6. Added “Save as Default” for Pro version.
      7. Added “Add Door Profile” button on tool bar and menu item.
      8. Added “Panel Profile” for Pro version. Users can create custom profiles.
      9. Added “Stile Profile” for Pro version. Users can create custom profiles.
      10. Added “Front Edge Profile” for Pro version. Users can create custom profiles.
      11. Added “Back Edge Profile” for Pro version. Users can create custom profiles.
      12. Added 5 Handle Styles for Pro version. Users can add their own handles.
      13. Added Handle Locations for Pro version.
      14. Added Handle Offset for Pro version.
      15. Added Bottom Rail Width for Pro version.
      16. Added Bottom Panel Height for Pro version.
        Version 1.0.21
      17. Fixed regression bug for “one click”
      18. Now only require vertical wood grain patterns
      19. Wood grain patterns now translated
      20. Added Spanish translation file. es.lang
        Version 1.0.20
      21. Fixed the draging operation. User can now chose any corner and drag to the opposite diagonal corner.
      22. Added config folder. Users should put their edited defaults.txt and or textures.txt files in this folder. They will be preserved with future updates.
      23. Added Chinese(Simplified) language file zh_cn.lang
        Version 1.0.19
      24. This version compatible with SU 2014
        Version 1.0.18
      25. first official release
      • guanjinG Offline
        guanjin
        1.0.18Not work well in sketcup2014, click on the toolbar icon, you can not open the dialog box.
        I come from China, is to learn
        • P Offline
          pomelo3d
          as is download?
          • G Offline
            Garry K
            You are right - 1.0.18 does not work with SU 2014
            I uploaded version 1.0.19 to Plugin Stores this morning.
            • guanjinG Offline
              guanjin
              @pomelo3d said:
              as is download?
              Activation Tool,No selection dialog。
              • G Offline
                Garry K
                Is this SU 2014 and 1.0.19 on Windows??
                • guanjinG Offline
                  guanjin
                  Thank you, have a private letter to you 👍
                  • KrisidiousK Offline
                    Krisidious
                    Drag option seems to put drawer on backwards starting from bottom right dragging to top left. all other start points put drawer off to sides.
                    can I 'select the area' make doors or drawers.
                    Ability to select lines while in menu to read entity info.
                    By: Kristoff Rand
                    • G Offline
                      Garry K
                      There are 3 drag options - All work from bottom left to bottom top.
                      The bottom left hand corner of the door / drawer is based on the first point chosen.
                      If you bottom right hand corner then top left hand corner then the door will be place backwards as if you are on the other side of the cabinet.
                      I'm not sure what you are asking?
                        Krisidious
                        got it. a note to that effect in the info text on the bottom might be good.
                        like "pick bottom left corner"
                        these are two different questions...
                        Can I 'select the area' make doors or drawers. I draw cabinets out or use my stock base and upper units, then I decide things per project like drawer fronts and tolerances. as you see in the screen grab If I could select a face I want to be drawer or door that would be awesome.
                        If I can't select a face and make it a drawer or door, then it would be nice if when I forget to find out what the size of door and drawer fronts are, I could click out side the menu, back in the model, while leaving the menu open. A few plugins do this, most don't.
                        By: Kristoff Rand
                        • G Offline
                          Garry K
                          Good idea! I will add this to my "to do" list for next version. It would also be simple to let user pick top left hand corner and then bottom right hand corner.
                          I think what you are asking is for a different interface where you pre select 1 or more face, bring up menu, set up tolerances and select door, drawer etc. Then click "OK" and convert ( delete and replace ) the faces with the door / drawer.
                          This would mean for each face I would have to detect which side is in and which side is out otherwise doors / drawers could be put on backwards. What happens if the faces aren't rectangular or if they are on a weird plane? I'm thinking there are a lot of tests.
                          Next version may include items like door handles ( positioning and selection ), user added profiles for edge and for panel raising etc.
                          I'm not sure that I could work with multiple faces and figure out door pull positions at the same time. I suppose for example, if user picked multiple faces where all of them could have a handle on the same relative location, that might work. But it might just add to the confusion because it would mean doing things in a very specific order.
                          Are you saying you want to suspend the door / drawer operation so you can perform some other sketchup operation like right click a line and read entity? So that you can get its length etc.
                          Currently if you make changes to the door menu (input box) and click OK or press enter, then the settings are still intact when you go back into the door menu. So you could:
                          1. make changes to door menu
                          2. click ok or press enter - box disappears and mouse cursor changes to door insert
                          3. press escape, choose a line, right click and choose "entity"
                          4. go back into door menu - last choices are all still intact. Adjust something based on what is in "entity". press enter or click ok.
                          Leaving a menu open means a rewrite for the interface. Change the sketchup inputbox to a web dialog box.
                          • G Offline
                            Garry K
                            Kristoff,
                            Version 1.0.20
                              Krisidious
                              Koooool. I'll give it a try.
                              By: Kristoff Rand
                              • OxerO Offline
                                Oxer
                                Thanks for the plugin!!
                                I have created the Spanish Language file.
                                Spanish Language
                                http://www.oxervision.blogspot.com/
                                • G Offline
                                  Garry K
                                  I am now working on the "pro" version of door maker.
                                  New menu items
                                  1. Add Edge Profile
                                  2. Add Panel Raise profile
                                  3. Add Handle
                                  New input values / drop downs
                                  1. Handle Style including "None"
                                    128 mm bar pul
                                    96 mm wire pull
                                    96 mm flat bar pull
                                    Round knob
                                  2. Handle location drop down possibilties:
                                    Top Left
                                    Top Center
                                    Top Right
                                    Center
                                    Bottom Left
                                    Bottom Center
                                    Bottom Right
                                  3. Handle Offset input value
                                  4. Front Edge profile drop down default values include:
                                    None
                                    Round over
                                    Bead
                                    Chamfer
                                    Cupboard
                                  5. Back Edge profile drop down default values include:
                                  6. Panel profile drop down default values include:
                                    Cove with bead
                                    Cove with ogee
                                    Cove with slant
                                    Slant with bead
                                    Slant with ogee
                                    Slant with slant
                                    Ogee with bead
                                    Ogee with ogee
                                    Ogee with slant
                                  7. Lower Rail height input value
                                  8. Lowest Panel height input value
                                    Krisidious
                                    Looks great Garry...
                                    By: Kristoff Rand
                                    • G Offline
                                      Garry K
                                      You will also be able to add door handles and pulls into the gkware_doormaker/handles folder and they will appear in the drop down list of handles.
                                      You will get 1 skp file with Edge profiles and 1 skp file as panel profiles. You can add more profiles and use the Add Edge Profiles button or Add Panel Profiles button. This will go through the geometry and add a file into the appropriate folder. The entries will then appear in the various drop down lists.
                                      These are examples of the supplied edge profiles.
                                      The one marked "Cupboard" is designed for the old style American Face Frame construction complete with a 10 mm x 10 mm rabbet. This can be accomplished by choosing "inlay" and by setting the gap to 8 mm and the protrusion to 12 mm.
                                      • MacG333M Offline
                                        MacG333
                                        Thanks for the plugin! Very nice and complete.
                                        I have created the italian language file.
                                        I hope you helpful.
                                        it.lang
                                        • unclebimU Offline
                                          unclebim
                                          Very nice options! Adding some more profiles and handles is very useful too, e.g. many customers want longer handles.
                                          What would be the pricing for the pro version of your DoorMaker plugin?
                                            Krisidious
                                            You'll be able to add profiles and handles to the library as you wish and I think the price will be between $10-$20US. Not sure though.
                                            By: Kristoff Rand
                                            • 1 / 3
