    Flatten surface without hidden geometry
    8 Posts 4 Posters 602 Views 4 Watching
      tranman100
      Hi guys,
      I am working on a site plan that has an uneven level of terrain. Is there a plugin to flatten all the terrain without showing the triangle hidden geometry? Flatten it would make any modifications on site much easier for me (e.g. street layout). I've attached an image of what i'm working with.
      Thanks!
      • cottyC Offline
        cotty
        You can hide the hidden geometry (View -> Hidden Geometry), but it will not change the discretisation of your terrain.
        edit: OK, didn't read the flatten in the question... 😒
        my SketchUp gallery
        • G Offline
          glro
          @tranman100 said:
          Hi guys,
          Thanks!
          maybe D BUR's projections plugin
          http://sketchucation.com/forums/viewtopic.php?t=20140
          one of the options enable to project on a plane
          • G Offline
            glro
            @tranman100 said:
            Hi guys,
            Thanks!
            TIG's flatten to plan
            http://forums.sketchucation.com/viewtopic.php?t=31908
            you need workplane
            http://forums.sketchucation.com/viewtopic.php?t=31204
              tranman100
              Exactly what I needed! Thanks guys! Sometimes there's so many plugins it's not always easy to find the exact one.
              • pbacotP Offline
                What is your work flow, if I may ask?
                  tranman100
                  I'm working on a site in Montreal. It's an urban design project. 😄
                  • pbacotP Offline
                    So you have a 3d site model. Then you are going to flatten it? Then what? Thanks!
