    Model 'Tea Tin' for Pay
    38 Posts 13 Posters 4.2k Views 13 Watching
    • mooarchiM
      mooarchi
      Hi All:
      Anyone want to model this tea tin? I need it both w/the photo texture mapped on, as well as a version with two textures (the black on the tin and the gold rim) so I can render it using VRay.
      Much appreciated!
      Susan
      Respectfully,
      Susan (Moses) O'Kane
      Moo Arch / Architecture & Design
      • gillesG
        gilles
        It should have take you less time to model this than to post as you're advanced.
        • majidM
          majid
          It is of my pleasure to do this. lots of fun
          • gillesG
            gilles
            @frederik said:
            Although I haven't setup materials for Vray, here's a quick model I made in less than 10 minutes (incl. the render in Thea)...
            I hope you can use it...!?
            Not sure I understand why you can't make such a simple model yourself, especially since you've set your SU skills to Advanced... 😐
            As long as somebody do the job for you. πŸ˜’
            • FrederikF
              Frederik
              Although I haven't setup materials for Vray, here's a quick model I made in less than 15 minutes (the render in Thea incl)...
              Size according to your info, but there's so many things, where I needed to eye ball (is this the correct term??) it and model...
              Not sure what you mean regarding "w/the photo texture mapped on"...?? πŸ˜•
              Any way... I hope you can use it...!?
              Side note...
              Tea-Tin.skp
              Cheers
              Kim Frederik
              • FrederikF
                Frederik
                Had a little spare time to make a few adjustment to the lid and base... πŸ˜„
                Again... Materials are setup to use with Thea Render, so you'll need to adjust them for Vray yourself...
                They're UV-mapped as cylinders, so you should be able to use a photo-texture... πŸ˜‰
                Tea-Tin_v2.skp
                Cheers
                Kim Frederik
                • JQLJ
                  JQL
                  Frederick,
                  Words for what? Master at work! FAST! I had to check to see if it was the same picture!
                  www.casca.pt
                  Visit us on facebook!
                  • FrederikF
                    Frederik
                    @JQL πŸ‘ πŸ˜„
                    Cheers
                    Kim Frederik
                    • pbacotP
                      I gather OP has lots to do and can use a little side help now and then.
                      • FrederikF
                        Frederik
                        Not sure what OP means...?? πŸ˜•
                        It's fair that people need a little help now and then...
                        However, as Gilles have mentioned, mooarchi have set her SU level to Advanced, and such an easy model could easily have been made in a similar time as it took to post this thread...
                        I made my model in app. 10 minutes... If need be, I can make a quick tutorial, showing how easy it is to make... πŸ˜„
                        Cheers
                        Kim Frederik
                        • BoxB
                          OP= Original Poster or Original Post depending on the context.
                          • gillesG
                            gilles
                            What I meant was I can spent hours helping a newbie with a particular problem but a so basic shape for an advanced user...
                            • FrederikF
                              Frederik
                              What annoyes me even more is, that I can see Susan has been online, but that she haven't even written a short THANK YOU...
                              It's happening far too often that users are asking for advice and help, but they never return, showing just a little gratitude... 😒
                              Cheers
                              Kim Frederik
                              • jeff hammondJ
                                jeff hammond
                                you guys scared her away from the sausage fest we have going on here πŸ˜’
                                πŸ˜†
                                @kim- nice looking model/render
                                dotdotdot
                                • StinkieS
                                  Stinkie
                                  That's not very surprising, given the, er, atmosphere. πŸ˜’
                                  • FrederikF
                                    Frederik
                                    Eehhh... You need to elaborate here, Tom... 😐
                                    I don't see a bad atmosphere or anything, but even if the atmosphere was a little tense, I would still show my gratitude, if I had asked others for help... 😐
                                    Cheers, Jeff... πŸ‘ πŸ˜„
                                    Cheers
                                    Kim Frederik
                                    • JQLJ
                                      JQL
                                      Hey Frederick,
                                      Here's my gratitude! I just remembered a project where this will be perfect. It will take some time to finish, but some shelves will be fast to fill! Thanks and best regards,
                                      JQL
                                      www.casca.pt
                                      • StinkieS
                                        Stinkie
                                        Et cetera. Anyway, nice model, nice render.
                                        • JQLJ
                                          JQL
                                          Well Tom that is definetelly true, however the post title and all the attitude related to it is justified IMHO.
                                          Title: Model 'Tea Tin' for Pay - wich implies someone needs a job well done and is willing to pay for it
                                          First post text: asking for help giving the subject and nicely put (though didn't mention payment conditions or specifying anything about payment)
                                          Replies: First of the responses was pretty amusing as an advanced user should be able to do this so fast that it really is wasted time to post here. As always in this forum there are several responses and then, someone with 20minutes spare time takes his time to help. I am absolutely sure that Frederick didn't even bother to read that there was payment involved at the title. Even if the job was simple enough, modeling, texturing, material and lighting really came out perfectly.
                                          Conclusion#1: No reply from the author, no thanks (I shouldn't even bother about talkinf of payment)
                                          Conclusion#2: The community (me actually) comes out with a simple yet excellent model for another project. Nothing is wasted here wich is great, but "here" exists because of willingful people that share and thank.
                                          www.casca.pt
                                          • gillesG
                                            gilles
                                            If I must apologize to cool down the "er atmosphere", well I do sincerely.
                                            Have a good week end everybody. β˜€
                                            • 1 / 2
