    Applying new Material to a Selection is extremely slow
    6 Posts 4 Posters 759 Views 4 Watching
    • fuzzybroF
      fuzzybro
      Hi all,
      Could you please suggest how to apply a newly created material to a whole bunch of faces in the selection?
      Right now I'm doing it by looping through all the faces/instances in the selection and assigning new material:
        materials = Sketchup.active_model.materials
        mat = materials.add "My New Material"
        entities = Sketchup.active_model.selection
        entities.each do |e|
          is_instance = is_instance?(e)
          is_face = e.is_a?(Sketchup;;Face)
          next if !is_instance && !is_face
          e.material = mat
          e.back_material = mat if e.is_a?(Sketchup;;Face)
      But it turns out to be extremely slow and doing the same thing via Paint Bucket Tool is blazing fast in comparison with assigning material via API.
      Is there a fast way of doing it via API?
      Cheers,
      Bro
      OctaneRender for SketchUp Overview and Demo Version
      Latest updates, tutorials and artwork
      facebook.com/octane4sketchup
      • tt_suT
        tt_su
        It'd be good if you had a test model and some metrics to your existing code.
        • dkendigD
          dkendig
          #component instances
          Sketchup.active_model.selection.grep(Sketchup::ComponentInstance){|inst| inst.material = mat}
          #groups
          Sketchup.active_model.selection.grep(Sketchup::Group){|grp| grp.material = mat}
          #faces
          Sketchup.active_model.selection.grep(Sketchup::Face){|f| f.material = mat;f.back_material = mat}
          Devin Kendig
          Developer
          • P
            pgarmyn
            @fuzzybro
            Put your code within
            Sketchup.active_model.start_operation("actionName", true,false,false)
            ..... Your code.....
            Sketchup.active_model.commit_operation
            This wil enable 'undo' for 'actionName' and the second parameter (false) wil disable screenupdate after each change of the model, until 'commit_operation'. API documentation says This can result in much faster Ruby code execution if the operation involves updating the model in any way.
            • fuzzybroF
              fuzzybro
              Hi all,
              Totally forgot about the "start_operation" thing.
              It worked out like a charm.
              Thanks!
              Bro
              • dkendigD
                dkendig
                good catch
                Devin Kendig
                Developer
