    Model in model sharing methods
    7 Posts 4 Posters 547 Views 4 Watching
    • onidarbeO Offline
      onidarbe
      I've written my own method p(msg) which adds information above and a line-number before the printed values, as in:
      4 p "hello" 5 p "world"
      ┌─┬─ filename ─ module::method ─ time.msec ─
      │ 4│ hello
      │ 5│ world
      I placed this in a separate plugin-file but under the same module name. So all p ... are printed now with more information, though when not having this plugin it still has normal p ... -puts
      Now I was wondering if I could have the p-method also in other modules of mine without making it global by not putting it in a module at all?
      #mr_main.rb;
      module MR
        def self.p(msg=nil)
          # Organises puts with line-numbers in a frame; ┌─┬─ filename ─ module;;method ─ time ─
          puts "┌───┬─ " # ... full version attached to this post ...
          puts msg
      #mr_test.rb;
      module MR
        module MR_test
          def self.test
            MR;;p "working"
            p "not working as I like it to call MR;;p"
          test
      • tt_suT Offline
        tt_su
        You could make it a mix-in module and include it into the modules you need.
        • onidarbeO Offline
          onidarbe
          mix-in module? How do I do that?
          • tt_suT Offline
            tt_su
            http://rubylearning.com/satishtalim/modules_mixins.html
            • onidarbeO Offline
              onidarbe
              Thank you, but even reading that twice and playing with it, I still don't see how to do it. I don't know if it's even possible what I'm trying.
              module MR
                def self.p(msg=nil)
                  puts msg
              module MR_test
                include MR
                MR;;p "hello" #working
                p "hello" #still not working ;(
                slbaumgartner
                Seems to me this depends on what you are really trying to achieve. Are these printouts for your own use during development and testing (most likely) or for your end users (seems unlikely as they probably won't have Ruby Console open and won't have any use for file and line info)? If the former, what is wrong with coding MR::p? You can then turn off the effect globally by editing just the MR module so that p does nothing. Also, you really don't want to pollute the global namespace with a variant method. That is reserved for the Trimble team 😲
                Steve
                • Dan RathbunD Offline
                  Dan Rathbun
                  try something like:
                  file "MR/MIX/P.rb"
                  module MR
                    module P
                      def p(msg="")
                        puts "from MR;;P; '#{msg}'"
                    # create a module function within module MR;
                    extend(P) # creates a singleton method
                  other files:
                  require("MR/MIX/P.rb")
                  module MR
                    module Test
                      p "Called p inherited down from Kernel"
                      include(MR;;P) # overrides the p() inherited from Object, as mixed in from Kernel
                      MR;;p "Called MR;;p"
                      p "Called p" # should call overridden p()
                      def self.pedigree()
                        puts "#{Module.nesting[0].name} ancestors; #{self.ancestors.inspect}"
                  I'm not here much anymore.
