    Random planting design plugin idea / question
    4 Posts 4 Posters 388 Views 4 Watching
    • U Offline
      unearthed
      Hi all and happy new year
      While English IS my language Maths is not so please excuse my bumbling...
      Would it be possible to use a spatial poisson-point random01 process (above) to generate semi-random, mixed plant size, mass planting plans within a defined (but irregular) shape?
      In my ideal world the user would (1) define an enclosing (most likely irregular) shape
      2 - Enter a series of circles of different diameters representing plants (preferably as components).
      3 - Enter an area coverage ratio for each plant (ie percent of shape area allocated to that species)
      4 - Enter a figure for repulsion to stop plants' circles overlapping each others' stems/centres and/or to vary plant density (see randomForest.jpg).
      The circle diameters and coverage rations could be premade in a txt file.
      I'd be happy if it was possible at first to generate a random set of points in a shape, that alone would help enormously. I'd also be happy to pay someone to write this if they thought it possible
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
        Not exactly what you want but the result will be the same! πŸ€“
        Try the crazzy Random Replace Components By Sdmitch 😎
        You can make anything with it with a little practice! πŸ˜‰
        • Didier BurD Offline
          Didier Bur
          Did you try my Components Spray ?
          DB
          • JQLJ Offline
            JQL
            And you should also check "Make fur" plugin!
            www.casca.pt
            Visit us on facebook!
