    No DLLS were Found in the Waterfall Procedure
    2 Posts 2 Posters 2.1k Views 2 Watching
    • Al HartA
      Al Hart
      A client reported this problem. Has anyone else run into this and/or have any suggestions for a better solution?
      http://api.ning.com/files/uY3PJt2fxPw1DFXhroswqEOqONQtMj5NlGR7slLfPSiIcCS*gSVaz642seqSOZiXm643s3C9R5fuyIsmJPLOJSaWQMoZwjrQ/NoDllsfound.png
      We offered this solution which seemed to work:
      In some cases after installing GoPro Studio, other applications may report an error that states: "Error at loading if ippSP library - No DLLS were Found in the Waterfall procedure".
      If this occurs the solution is to browse to: C:\Windows\SysWOW64 and then remove these files:
          ippcore-6.1
          ippj-6.1
          ippjw7-6 .. 1
          IPPS-6.1
          ippvc-6.1
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • S
        SeeSite
        Yep, just now ran into this after installing GoPro.
        This solution fixed it. Many Thanks !!!
