    Code problem between windows-versions ??
    5 Posts 2 Posters 308 Views 2 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      i have a strange problem:
      in windows vista / skp 8 and skp 6 this peace of code (within the whole ruby) works perfectly (the group is copied, named and transformed copy-times:
      angle = @arena_angle_half*2
      		puts angle
      		entities = @group_stair.entities
      		group_arena = entities.add_group
      			for copy in 1..@arena_angle_devider
      			angle1 = copy *  angle
      			group = @group_stair.copy
      3863			group.name = "arena-copy" + copy.to_s
      			tr = Geom;;Transformation.rotation(point,vector,angle1)
      			@entities2.transform_entities(tr, group.entities.to_a)
      to my surprise, it does not work on
      win 7 / skp 8
      win xp / skp 8
      this error is reported in the console
      Error: #<NoMethodError: undefined method name=' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:3863:in arena'
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:3860:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:3860:in arena'
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:212
      has anybody an idea, what this problem could be?
      thank you very much!
      stan
      • tt_suT Offline
        tt_su
        Do you have the same plugins installed in all the SketchUp versions. sounds like you are suddenly getting a nil from @group_stair.copy - there might be some plugins that override this and change it's behaviour.
          artmusicstudio
          hi tt, although i synchronise the plugin-folders carefully,
          making the win7 folder empty in deed was the solution.
          so now i have to find out , which plugin has a conflict and can correct my code.
          it was the first time, something like that happend. interesting!
          thanx a lot for your "expert's eye".
          stan
          ps: i just wonder, where to send all the cookies afterwards,,,,
          • tt_suT Offline
            tt_su
            You try to search the RB files for "class Sketchup::Group" or "def copy" - hoping the culprit is not scrambled. Might same you some investigation time.
              artmusicstudio
              hi,
              problem solved, it was sketchy physics. i will try to redifine my code later, maybe i will find the problem.
              stan
