Code problem between windows-versions ??
hi,
i have a strange problem:in windows vista / skp 8 and skp 6 this peace of code (within the whole ruby) works perfectly (the group is copied, named and transformed copy-times:
angle = @arena_angle_half*2 puts angle entities = @group_stair.entities group_arena = entities.add_group for copy in 1..@arena_angle_devider angle1 = copy * angle group = @group_stair.copy 3863 group.name = "arena-copy" + copy.to_s tr = Geom;;Transformation.rotation(point,vector,angle1) @entities2.transform_entities(tr, group.entities.to_a) endto my surprise, it does not work on
win 7 / skp 8
win xp / skp 8this error is reported in the console
Error: #<NoMethodError: undefined method
name=' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:3863:inarena'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:3860:ineach' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:3860:inarena'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:212has anybody an idea, what this problem could be?
thank you very much!
stan
Do you have the same plugins installed in all the SketchUp versions. sounds like you are suddenly getting a nil from @group_stair.copy - there might be some plugins that override this and change it's behaviour.
hi tt, although i synchronise the plugin-folders carefully,
making the win7 folder empty in deed was the solution.so now i have to find out , which plugin has a conflict and can correct my code.
it was the first time, something like that happend. interesting!
thanx a lot for your "expert's eye".
stan
ps: i just wonder, where to send all the cookies afterwards,,,,
You try to search the RB files for "class Sketchup::Group" or "def copy" - hoping the culprit is not scrambled. Might same you some investigation time.
hi,
problem solved, it was sketchy physics. i will try to redifine my code later, maybe i will find the problem.
stan
