    Get latLong of origin?
    7 Posts 4 Posters 1.3k Views 4 Watching
    • TomPendergrassT
      TomPendergrass
      Greetings, users!
      I'm trying to find the point where a photo was taken in relation to a sketchup scene. The scene has been geolocated and has buildings constructed in their proper locations. I have the EXIF data of the photo: lat long, altitude, etc. Is there a way to plug this information into a ruby script and find the point?
      My approach was to get the lat long of the scene's origin and finding the point by calculating distance and direction between the two locations.
      Thank you ahead of time for any insight into my predicament!
      • S
        slbaumgartner
        @tompendergrass said:
        Greetings, users!
        This snippet example from the API documentation creates a construction point at the specified lat, lon:
         # Draw a point in Boulder, Colorado (40.0170N, 105.2830W)
         lnglat_array = [-105.28300, 40.01700]
         model = Sketchup.active_model
         point = model.latlong_to_point lnglat_array
         model.entities.add_cpoint(point)
        presumably you could set the z (blue) component of the point to your altitude.
        Steve
        • Dan RathbunD
          Dan Rathbun
          IF there is no bugs re: this in your SU version.
          Verify he page shado_info is ON:
          page.use_shadow_info= true
          Then get the lon & lat:
          lon = page.shadow_info["Longitude"] lat = page.shadow_info["Latitude"]
          You can create an API Geom::LatLong object:
          llo = Geom::LatLong::new( [lat,lon ] )
          There is also a Geom::UTM class in the API.
          πŸ’­
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            Also some SketchUp functionality (Google Earth, etc.) creates AttributeDictionary objects that have Lat and Long attributes.
            I think I published an example code snippet here.
            Check the Code Snippets Index (It's a sticky post at the top of this forum.)
            Edit: It is [ Code ] GE "GeoLocation" AttributeDictionary v1.1.0
            πŸ’­
            • tt_suT
              tt_su
              Yes, model.latlong_to_point should work. Though, for the altitude, I'm not sure if SketchUp takes that into account when it geo-locates models. I'd have to dig around to see if you can get the altitude of the geolocated model - so you can get the height right.
              • Dan RathbunD
                Dan Rathbun
                The "onOceanFloor" attribute of the "GeoLocation" dictionary is supposed to set the base (zero line,) for the altitude (IF exporting for Google Earth.)
                The Ocean Modeling extension by "The SketchUp Team" adds a menu item to toggle add or delete the attribute. (If you are not modeling ocean floor shipwrecks, then you do not need the extension.)
                • TomPendergrassT
                  TomPendergrass
                  Thank you for your help! Turns out the camera that the photos were taken off of had some weird GPS offset, which is why my photos were imported yet placed kilometers away. I solved my problem by using a 'reference point'. I have the user import one photo and place that photo where they believe it was taken. I use that photo's lat and long to modify the rest of the photos that were imported. Success πŸ˜„
