    Offset-function per ruby (simple)
    6 Posts 4 Posters 645 Views 4 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      is there an equivalent for the skp-function "offset" in ruby for simple forms like square or circle ?
      thanx stan
      • Dan RathbunD Offline
        Dan Rathbun
        If you group the objects it makes things much simplier:
        g.move! [1,1,0]
        Moves the group by the vector array argument. (The API dictionary says the arg should be a Geom::Transformation instance, but the method also takes an array representing a vector.) Does NOT add the move to the Undo stack.
        g.transform! [1,1,0]
        Moves the group by the vector array argument. (The API dictionary says the arg should be a Geom::Transformation instance, but the method also takes an array representing a vector.) ADDS the move to the Undo stack as "Move".
        I would assume that these methods may also accept a Geom::Vector3d argument ?
        πŸ’­
        I'm not here much anymore.
          Dan Rathbun
          For simple objects you can move them without grouping.
          Assume c is the reference to a circle object.
          c.parent.entities.transform_entities( [1,1,0], c )
          Or for an array [e1,e2,e3,e4] of edges making up a square:
          e1.parent.entities.transform_entities( [1,1,0], [e1,e2,e3,e4] )
          • The above methods add to the undo stack.
          Also be aware strange results may happen if the entities to be moved are not in the current editing context.
          πŸ’­
            slbaumgartner
            @artmusicstudio said:
            hi,
            thanx stan
            Were you looking to move objects, per Dan's replies, or for a Ruby equivalent to the offset tool (i.e. to create a "parallel" shape inside or outside the original)?
              artmusicstudio
              hi,
              thanx stan
              hi, slbaumgartner,
              yes , you got it,
              what i look for here (though dan's advice is also helpful for other things)
              is in deed the offset-function, creating a parallel shape (only simple forms like rectangles or circles).
              stan
              • icehuliI Offline
                icehuli
                hi,
                thanx stan
                hi, slbaumgartner,
                yes , you got it,
                stan
                you can try this:
                http://www.smustard.com/script/Offset
                simply works for faces(polygons) and polylines
