    [Plugin] AMS Library 3.7.1b (29 May 2021)
    108 Posts 39 Posters 664.2k Views 39 Watching
      rcatedra @Dan Rathbun
      Thanks for your quick reply. My version is 2016, it's the first time I try to use the keyboard script, and all the samples seen in internet uses this "key" method as keyboard input, but is not working in my 2 different computers. Maybe it left working with some distributable Microsoft visual C++ library or whatever... I don't know if somebody else could bring me a clue about that.
      Anyway, thanks for your time Dan.
        rcatedra
        Finally I get a solution writting this:
        It's seems the "alias" key is not working and now it must be used the get_key_state method. In addition also I have to use the path AMS::Keyboard to access to keyboard library.
        I let this post in case somebody else want to use the keyboard function in MSphysics.
        Regards
          cstone2475
          Thank U~
          • P Offline
            paradoxprotector Newcomers
            Update the Plugin:
            • Hello, Can you Update this Plugin (AMS Library 3.7.1b ) for SketchUp 2023 and 2024 Version Plz I really Need.
              Thanks.
            N 1 Reply Last reply Reply Quote 0
              mdrashed Newcomers
              thank you
              • N Offline
                nohangb @paradoxprotector
                @paradoxprotector said in [Plugin] AMS Library 3.7.1b (29 May 2021):
                Thanks.
                Alguem sabe se ja atualizaram para SKP 2024?
                Does anyone know if they have already updated to SKP 2024?
                  a4jp.com
                  Got a version that works with SketchUp 2024?
                  • O Offline
                    Oblepiha @Anton_S
                    @anton_s Антон, здравствуйте! Ваше приложение MSPhysics прекрасно! Оно позволяет делать очень крутые вещи! К сожалению на новых версиях SketchUP библиотека и приложение не работает. Подскажите, возможно ли обновить эти плагины для актуальных версий? Мне необходима эта программа для работы, так что, готов плагин купить. А пока продолжу использовать его на версии SU2017
                    • 6
                    • 6 / 6
