    LoopLab Help
    3 Posts 3 Posters 454 Views 3 Watching
    • renderizaR
      renderiza
      Hi, the following code is part of a plugin called LoopLab and I am seeking help in resolving an issue. Right now the tool can't select multiple loops and was wondering if anyone has an idea on how to solve this issue. Thanks in advance!
      model = Sketchup.active_model
      sel = model.selection
      edges = sel.grep(Sketchup;;Edge)
      use = edges.last
      rerun = edges.last
      run = true
      stp1 = false
      stp2 = false
      skip = true
      model.start_operation('LoopLab')
        begin
        edge = use
        faces = edge.faces
        v1 = edge.start
        v2 = edge.end
        v1_edges = v1.edges
        v2_edges = v2.edges
        break if v1_edges.length > 4 || v2_edges.length > 4
        v1_edges.to_a.each { |ne|
          if not ne.used_by? faces[0] and not ne.used_by? faces[1] and not sel.include?(ne)
            use = ne
            sel.add ne
            stp1 = false
            break
          else
            stp1 = true
        if skip == true
          skip = false
          next
        v2_edges.to_a.each { |ne|
            use = ne
            sel.add ne
            stp2 = false
            break
          else
            stp2 = true
        if stp1 and stp2
          run = false
      end while run
      run = true
      stp1 = false
      stp2 = false
      skip = true
      begin
        edge = rerun
        faces = edge.faces
        v1 = edge.start
        v2 = edge.end
        v1_edges = v1.edges
        v2_edges = v2.edges
            rerun = ne
            sel.add ne
            stp1 = false
            break
          else
            stp1 = true
        if skip == true
          skip = false
          next
            rerun = ne
            sel.add ne
            stp2 = false
            break
          else
            stp2 = true
        if stp1 and stp2
          run = false
        end while run
      model.commit_operation
      Sketchup.send_action('selectSelectionTool;')
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • Dan RathbunD
        Dan Rathbun
        Usually you hold the keyboard CTRL key to add items to the selection set.
        I'm not here much anymore.
        • tt_suT
          tt_su
          You can collect all the separate loop-segments from the selection and then treat them separately.
          If you made the assumption that the user only selected one edge in each of the loops he/she wants selected then it's easier - as you just need to iterate each edge in selection and build a loop for each one.
          But it could be that the user selected multiple segments of a loop, in which you would have to detect this as well. Or, thinking of it, you could just ignore the fact that some are connected, just build the loop anyway and make sure you don't process an edge that's already in a generated loop.
