Basic question - groups as array ?
hi,
is it possible to create and define GROUPS as ARRAY?example: #create needed groups for later element assignment
$groupname[0] = Sketchup.active_model.entities.add_group $groupname[0].entities.add_line([0,-50,0],[0,-50,140]) #element [0] will be later deleted $groupname[0] = "$groupname[0]" $groupname[1] = Sketchup.active_model.entities.add_group $groupname[1].entities.add_line([0,-50,0],[0,-50,140]) #element [0] will be later deleted $groupname[1] = "$groupname[1]" .....after this, one could assign elements to those groups within a loop using a
the loop-step as the arry-indexthanx stan
(1) Creating groups for later use requires at least 1 entity in them, so we usually add a cpoint into them at
ORIGIN(the predefined global constant which is aGeom::Point3d == [0,0,0].)(2) Ruby does NOT have variables. It has 2 things. Objecs and references to those objects.
You can create as many references to a single object as you wish, depending upon your needs.
a = []ais a reference to a Ruby instance of classArray.A Ruby array is a non-unique collection of references to other objects.
(3) So YES you CAN use arrays to hold references to ANY kind of object you wish.
(4) You need to stop using global references, and use module, class, instance or local references, within your own namespace
module:module AMS module SomePlugin @@groups = [] unless defined?(@@groups) # other code end # SomePlugin end # AMS
Mind describing what you are trying to achieve on a more abstract level?
@artmusicstudio said:
... after this, one could assign elements to those groups within a loop using a the loop-step as the array-index
You CAN use an index, but it is not needed:
@@groups.each {|g| g.entities.add_line([0,-50,0],[0,-50,140] }IF you WANT to use an index:
0.step( @@groups.size-1, 2 ) {|i| ents = @@groups[i].entities ents.add_line([0,-50,0],[0,-50,140] }But you can also use the
each_with_indexmethod, (because theEnumerablemodule is mixed into theArrayclass:@@groups.each_with_index {|g,i| if i.remainder(2).zero? # even indices only ents = g.entities ents.add_line([0,-50,0],[0,-50,140] end # only even } -
hi, thank you all, i tried to put my groups in the suggested ways into a loop, but i always get errors. with '@@groups' i would reach all grups, wouldn't i ?
i will try to describe the whole problem:i have a defined amount of groups with one basic construction point (thanx dan), the amount changes by user input, so it must be variable, so there may be 2 or 20 @group_handlauf_mitte - groups.
@group_handlauf_mitte1
@group_handlauf_mitte2
@group_handlauf_mitte3
@group_handlauf_mitte4
and so oni cannot find out, how can i access those 'group_handlauf_mitte ' groups in a loop to be able to select a group by
@group_handlauf_mitte[index].entities. (my index here ist PODESTNR)i also tried to create the group name as a string-combination within a loop
for step 1..20 a = "group" + step.tp_s.name a.name = a endbut that's obviously not working , too.
at the moment i have to define like this:
if @podestnr == 1 entities = @group_handlauf_mitte1.entities new_line = entities.add_line rl13, rl14 entities = @group_handlauf_mitte1.entities elsif @podestnr == 2 entities = @group_handlauf_mitte2.entities new_line = entities.add_line rl13, rl14 entities = @group_handlauf_mitte2.entities elsif @podestnr == 3 entities = @group_handlauf_mitte3.entities new_line = entities.add_line rl13, rl14 entities = @group_handlauf_mitte3.entities elsif @podestnr == 4 entities = @group_handlauf_mitte4.entities new_line = entities.add_line rl13, rl14 entities = @group_handlauf_mitte4.entities endinstead of this i would like to make a loop in which STEP decides, which grop's entities will become ENTITIES, but only for those groups, not all groups i have.
hopefully i can once understand the syntax for group selection by index, because i could then make the ruby-code many times shorter.
in this loop i need the griup name 1,2,3,4 to become dependent from the index MTH
model = Sketchup.active_model y1 = 0 - @run ## the overall variables come from earlier code !!! y2 = 0 y3 = @run z = @rise pf = [] for mth in 1..10 entities = @group_handlauf_mitte1.entities ### MTH instead of 1 needed entities.erase_entities entities[0] rl1 = [0, y1, 0] rl2 = [0, y2, z] group = @group_handlauf_mitte1 = entities.add_group ### MTH instead of 1 needed entities2 = @group_handlauf_mitte1.entities ### MTH instead of 1 needed new_line = entities2.add_line rl1, rl2 length = new_line.length pf[mth] = [0, 0 - @run+@run*@il*(mth-1)+@run*@la*(mth-1)+@ro.abs, (mth-1)*@il*@rise+@sr] #mitte #point1 = Geom;;Point3d.new pf51 #constpoint = entities.add_cpoint point1 centerpoint = pf[mth] new_line = entities2.add_line rl1, rl2 vector = new_line.line[1] vector2 = vector.normalize! edges = entities2.add_circle centerpoint, vector2, @thradius kreis = entities2.add_face edges entity1 = entities[0] kurvem = entity1.all_connected status1 = kreis.followme kurvem endthanx for helping
stan
Register LoginAdvertisement
