    Basic question - groups as array ?
    5 Posts 3 Posters 362 Views 3 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      is it possible to create and define GROUPS as ARRAY?
      example: #create needed groups for later element assignment
      $groupname[0] = Sketchup.active_model.entities.add_group
      $groupname[0].entities.add_line([0,-50,0],[0,-50,140])   #element [0] will be later deleted
      $groupname[0] = "$groupname[0]"
      $groupname[1] = Sketchup.active_model.entities.add_group
      $groupname[1].entities.add_line([0,-50,0],[0,-50,140])   #element [0] will be later deleted
      $groupname[1] = "$groupname[1]"
      after this, one could assign elements to those groups within a loop using a
      the loop-step as the arry-index
      thanx stan
      • Dan RathbunD Offline
        Dan Rathbun
        (1) Creating groups for later use requires at least 1 entity in them, so we usually add a cpoint into them at ORIGIN (the predefined global constant which is a Geom::Point3d == [0,0,0].)
        (2) Ruby does NOT have variables. It has 2 things. Objecs and references to those objects.
        You can create as many references to a single object as you wish, depending upon your needs.
        a = []
        a is a reference to a Ruby instance of class Array.
        A Ruby array is a non-unique collection of references to other objects.
        (3) So YES you CAN use arrays to hold references to ANY kind of object you wish.
        (4) You need to stop using global references, and use module, class, instance or local references, within your own namespace module:
        module AMS
          module SomePlugin
            @@groups = [] unless defined?(@@groups)
            # other code
          end # SomePlugin
        end # AMS
        πŸ’­
        I'm not here much anymore.
        • tt_suT Offline
          tt_su
          Mind describing what you are trying to achieve on a more abstract level?
            Dan Rathbun
            @artmusicstudio said:
            ... after this, one could assign elements to those groups within a loop using a the loop-step as the array-index
            You CAN use an index, but it is not needed:
            @@groups.each {|g|
              g.entities.add_line([0,-50,0],[0,-50,140]
            IF you WANT to use an index:
            0.step( @@groups.size-1, 2 ) {|i|
              ents = @@groups[i].entities
              ents.add_line([0,-50,0],[0,-50,140]
            But you can also use the each_with_index method, (because the Enumerable module is mixed into the Array class:
            @@groups.each_with_index {|g,i|
              if i.remainder(2).zero? # even indices only
                ents = g.entities
              end # only even
              artmusicstudio
              hi, thank you all, i tried to put my groups in the suggested ways into a loop, but i always get errors. with '@@groups' i would reach all grups, wouldn't i ?
              i will try to describe the whole problem:
              i have a defined amount of groups with one basic construction point (thanx dan), the amount changes by user input, so it must be variable, so there may be 2 or 20 @group_handlauf_mitte - groups.
              @group_handlauf_mitte1
              @group_handlauf_mitte2
              @group_handlauf_mitte3
              @group_handlauf_mitte4
              and so on
              i cannot find out, how can i access those 'group_handlauf_mitte ' groups in a loop to be able to select a group by
              @group_handlauf_mitte[index].entities. (my index here ist PODESTNR)
              i also tried to create the group name as a string-combination within a loop
              for step 1..20
              a = "group" + step.tp_s.name
              a.name =  a
              but that's obviously not working , too.
              at the moment i have to define like this:
                                                      if @podestnr == 1
              					entities = @group_handlauf_mitte1.entities
              					new_line = entities.add_line rl13, rl14
              					elsif @podestnr == 2
              					entities = @group_handlauf_mitte2.entities
              					elsif @podestnr == 3
              					entities = @group_handlauf_mitte3.entities
                     					elsif @podestnr == 4
              					entities = @group_handlauf_mitte4.entities
              instead of this i would like to make a loop in which STEP decides, which grop's entities will become ENTITIES, but only for those groups, not all groups i have.
              hopefully i can once understand the syntax for group selection by index, because i could then make the ruby-code many times shorter.
              in this loop i need the griup name 1,2,3,4 to become dependent from the index MTH
              model = Sketchup.active_model
               y1 = 0 - @run ## the overall variables come from earlier code !!!
               y2 = 0
               y3 = @run
               z = @rise
               pf = []
               for mth in 1..10
                          entities = @group_handlauf_mitte1.entities ### MTH instead of 1 needed
                          entities.erase_entities entities[0]
                          rl1 = [0, y1, 0]
                          rl2 = [0, y2, z]
              group = @group_handlauf_mitte1 = entities.add_group      ### MTH instead of 1 needed
                          entities2 = @group_handlauf_mitte1.entities  ### MTH instead of 1 needed
                          new_line = entities2.add_line rl1, rl2
                          length = new_line.length
               pf[mth] =  [0,  0 - @run+@run*@il*(mth-1)+@run*@la*(mth-1)+@ro.abs, (mth-1)*@il*@rise+@sr] #mitte
                         #point1 = Geom;;Point3d.new pf51
                         #constpoint = entities.add_cpoint point1
                         centerpoint = pf[mth]
                         vector = new_line.line[1]
                         vector2 = vector.normalize!
                         edges = entities2.add_circle centerpoint, vector2, @thradius
                         kreis = entities2.add_face edges
                         entity1 = entities[0]
                 	   kurvem = entity1.all_connected
               	   status1 = kreis.followme kurvem
              thanx for helping
              stan
