    🫛 Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Newbie w/ a new hobbie
    35 Posts 5 Posters 971 Views 5 Watching
      Coach_Travis
      Dave - Thank you for the tips. The thing about baseball fields is the guides are used for multiple things. I will need most of those lines in the future.
      You are right about the face colors. Sometimes I can not tell if it is a shade or not. I am going to change my face colors.
      • BoxB Offline
        You can turn the visibility of Guides on and off, View menu/Guides
          Coach_Travis
          Box - Thanks for the tip.
          • BoxB Offline
            Another small tip before you go too far. Make sure you know about Groups and Components and how they separate geometry and make repetition easy.
              Coach_Travis
              Yeah, I need to research that more.
                Coach_Travis
                Dave - Changing the face color really assisted. Thank you again.
                  Coach_Travis
                  I got the batter's boxes and catcher's box done this morning.
                    Coach_Travis
                    Is there a way to copy the dugout on the first base side and paste it to the third base side?
                    • BoxB Offline
                      Yes, there are many ways. One of the most basic is to select the geometry of the dugout and use Copy and Paste.
                      But SU makes it easier, many tools allow you to move and copy things at the same time.
                      The Move tool for example, if you select geometry, then using the Move tool, Hold down CRTL and click then move and it will create a copy of what you have selected. The same works with the rotate tool, so you could find the center of your field and rotate a copy of the dugout to the new position.
                      This then brings you to components, if you make the dugout a component it becomes it's own little package of geometry that won't stick to anything. You can then copy it to the other position and any edits to one will happen to the other.
                        Coach_Travis
                        I made the one dugout a group, copy, and then pasted it. However, I am having problems trying to move it into place. I looked at a tutorial but I can not seem to finesse it into place. Are there any easy tips to get this into place?
                          Coach_Travis
                          In addition, in SU 8 I was able to change the lines to the axis color? Did this option go away in SU 2013?
                          Attention Required! | Cloudflare
                          (help.sketchup.com)
                          • BoxB Offline
                            I did this little vid some time back for someone else, hope it makes sense and gives you a few tips.
                            [screenr:noaa6anj]4CQ7[/screenr:noaa6anj]
                            • BoxB Offline
                              Colour by axis is in Styles.
                                Coach_Travis
                                Box - I had been messing with that for 30 minutes or better. I watcher you tutorial and got it within a second. Thank you very much.
                                  Coach_Travis
                                  Box - Again, thank you. I had the faces option from before. I had to go to the edges option.
                                  • 2 / 2
