    Windmills
    24 Posts 13 Posters 4.3k Views 13 Watching
      davidh
      3 images previously uploaded to the Thea site.
      The windmills were downloaded from the 3d warehouse and rendered in Thea with landscape added in photoshop.
      The renders are done using interactive mode in thea and took about 5 minutes each.
      • cottyC Offline
        cotty
        Nice!
        Maybe you can change the rotation diffently so that they don't look like crosses.
        my SketchUp gallery
          David, brilliant as usual. One day etc etc. I sencerely hope your images earn you good money, giving them away like this must cost you a small fortune and I would rather look at YOUR work than the guff in the national gallery. At least your product has integrity.
          As a side issue, these would make fantastic hdri images if there were a way to do so.
            davidh
            Thanks Mike,
            Nearly everything I upload is purely a test,a version of how I would want to light a particular subject,sometimes they work,other times they don't.
            For every image I upload I would have at least a half dozen that just don't work.
            One of these days I will upload an image I am really happy with and once that happens,
            thats it! I'm done!
              tomislavm
              Nice!
              And change the rotation !
              • KrisidiousK Offline
                Krisidious
                Fantastic...
                By: Kristoff Rand
                  davidh
                  2 more images,the first is a version of the original older windmills set just before an upcoming storm.
                  The storm clouds are based on an image I downloaded from the net but darkened considerably on the right and used the dodge tool in photoshop to increase the brightness on the extreme left to add to the ominous mood,and pick up some highlights on the buildings themselves.
                  The second is a more american style wind generator.The building is one I have uploaded in multiple images previously.
                  • BoxB Offline
                    Great images but I think you are doing yourself a disservice by keeping the sails vertical.
                    The language of sails is quite complex and what yours are saying is they are talking a short break but they are busy milling. You would almost never have multiple windmills saying that at the same time.
                    The diagonal cross position is the default for we have stopped milling. The one o'clock position is generally used to announce good news, a birth or a festival or some such and the 11 o'clock position is used to announce a death. You'll often find all the windmills in a region set in mourning for a funeral. There are many other coded positions, often used in combination with flags and other visual clues, that were used to spread news quickly around the area.
                    • DanielD Offline
                      Daniel
                      Looks like a nice day for jousting...
                      Beautiful images, as always, Davidh
                      My avatar is an anachronism.
                      • Bryan KB Offline
                        ๐Ÿ˜ฎ Wow. Incredible images.
                        • pbacotP Offline
                          Great images.Light and sky especially.
                          RE the windmills, I guessed that multiple mills in a flat area meant they were pumping water out of tidal lands, not milling. Or do grain mills tend to congregate in the wastelands? I don't think we had them much in the US, did we? Water-driven mills were used.
                          • artysmediaA Offline
                            artysmedia
                            I like the third image. It looks like the planet Tatooine from Star Wars ๐Ÿ˜†
                            Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                            Blog: Artysmedia
                              davidh
                              That iconic image from star wars was actually one of my references when doing the third image,particularly the sky colour and low orange sun -
                              here's a slightly different version!
                              • cottyC Offline
                                cotty
                                @davidh said:
                                ...here's a slightly different version!
                                here too... (I hope it does not matter to you.) ๐Ÿ˜‰
                                (find the differences)
                                my SketchUp gallery
                                  davidh
                                  One thing I would say about your version is that the birds are way too much prominent in the image.
                                  If they were as close to the camera as your image would suggest,they wouldnt be as dark or lacking detail.
                                  The whole idea of my original image is that the landscape and sky reflected no movement - a snapshot of stillness.
                                  I would also say that if you want to add movement in an image and want to add birds, - think about them as part of your idea rather just sticking some entourage in.
                                  Give everything you add-in-post the same respect you give to your render.
                                  • olisheaO Offline
                                    olishea
                                    I think the crosses may be symbolic perhaps? Works for me.
                                    oli
                                    • Bryan KB Offline
                                      Oops. Double post.
                                      • tinanneT Offline
                                        tinanne
                                        ๐Ÿ‘
                                        Executive Director : American Society of Architectural Illustrators
                                        AIP 30 Competition opens soon. ASAI.org
                                        Architectural Rendering
                                        • majidM Offline
                                          majid
                                          Wow David
                                          I always like the way you do the job and wishing try something like this,
                                          here is an attempt
                                          ready model 3DWH, Thea, Photoshop
                                          detail
                                          balanced
                                            davidh
                                            Majid,
                                            These are excellent,I particularly like the long landscape with the context of the surrounding area.
                                            • 1 / 2
