    Coffee table w/ lift top for laptop work
    15 Posts 8 Posters 2.9k Views 8 Watching
    • G
      Gene Davis
      Just saw this in an ad flier. Great idea, but should have less a pedestrian look than this RTA thing.
      Ideas?
      Mission style preferred, but that's just me.
      That space under, when you lift it up, is where the laptop can be residing. Good lift hardware is the key for this one.
        Have you ever seen the hardware? How much space does it take up when the top is down?
        • G
          Gene Davis
          Just saw it in the flesh. Photographed the hdwe and will post later. Will go back to store for better look and measure everything. The top action, up and down, is nice, and when up, is perfect height for laptop work from couch. The store had one in a seating group, couch on long side.
            Cool. Did you measure how far the top shifts horizontally. I was thinking about a coffee table with legs and aprons but there might not be enough weight to prevent it from tipping when the top is up and there's a laptop or something on it.
            • V
              Vicspa
              Here's one from Brookstone.
              • Jean-FrancoJ
                Jean-Franco
                I drew for a friend a coffee table with a similar system but all made with wood.
                Just for ideas.
                Jean-Franco
                • M
                  mrossk
                  FYI, Rockler sells this hardware...
                  https://www.mkaplanfinefurniture.com/
                  • G
                    Gene Davis
                    What is interesting me as regards hardware, is the price of the complete RTA unit I was seeing today at the Farm & Fleet store, an item made by Sauder, is selling for something like $100. All the Souder stuff is discounted this week.
                    I cannot find the hardware anywhere online for a price close to this.
                    So, buy the kit (yes it is a kit with the hardware unmounted) and throw away all but the metal. Then make a nice one.
                    OTOH, the wooden one might be best. One could prototype it for little material expense, fine tune things, and then do the real thing.
                    FWIW, I have attached a pic of the hardware that comes with the RTA Souder table. Pretty beefy stuff, with a nice spreader strap running side to side to minimize wobble.
                    • G
                      Gene Davis
                      And it's only 99 bucks, which is a great price for the hardware PLUS a CNC-cut prototype that can be used for the hole-drill template.
                        Cool idea. Are you going to buy the kit?
                          How about something like this? Move the drawer over a bit, center it or leave it out.
                          • soloS
                            solo
                            Just saw this in my FaceBook feed.
                            http://www.solos-art.com
                            • M
                              mrossk
                              $40.00 at Woodworkers Supply! : http://woodworker.com/coffee-table-top-lift-mechanism-lr-mssu-164-228.asp
                              or what looks to be a nicer unit at Lee Valley for $190 : http://www.leevalley.com/US/wood/page.aspx?p=40573&cat=3,43586,43594&ap=1
                              • BoxB
                                I woke up with an addition to your table in my mind. Make the top from two pieces, put a couple of locking posts in the bottom layer and a track in the top layer and you can spin and slide the top to form a gaming table or whatever. Much more versatile, but you'd probably need to have some good weight in the base to counterbalance it at full extension.
                                • W
                                  watkins
                                  The mechanism seems to be quite inexpensive
                                  http://www.dhgate.com/product/pop-up-coffee-table-mechanism-coffee-table/159316171.html
                                  Regards,
                                  Bob
