    Intersect_line_line question
    8 Posts 3 Posters 736 Views 3 Watching
    • s_k_e_t_c_h_yS
      s_k_e_t_c_h_y
      I'm having trouble with Geom.intersect_line_line not giving the expected results so I was hoping someone could either tell me what I'm doing wrong or that the function is bugged so I know whether to rewrite it.
      According to the documentation in the API
      Geom.intersect_line_lineSketchUp 6.0+
      The intersect_line_line computes the intersection of two lines.
      Arguments:
      line1
      The first line to intersect.
      line2
      The second line to intersect.
      Returns:
      point
      The intersection point. Returns nil if they do not intersect.
      line1 = [Geom::Point3d.new(10,0,0), Geom::Vector3d.new(1,0,0)]
      line2 = [Geom::Point3d.new(0,10,0), Geom::Point3d.new(20,10,0)]
      pt = Geom.intersect_line_line(line1, line2)
      This will return the point (10,10,0).
      If you type in their example into the Ruby editor it doesn't actually work as advertised, it returns nil.
      Here is an example of two parallel lines returning a value...
      l1 = [[0,0,0], [10,0,0]]
      [[0, 0, 0], [10, 0, 0]]
      l2 = [[0,5,0], [10,5,0]]
      [[0, 5, 0], [10, 5, 0]]
      i = Geom.intersect_line_line(l1, l2)
      Point3d(-10, 0, 0)
      Thoughts?
      Sincerely, Paul.
      • Dan RathbunD
        Dan Rathbun
        Yes there are many errors in the API dictionary.
        The code example has the wrong vector argument for line1, and the example should read:
         line1 = [Geom;;Point3d.new(10,0,0), Geom;;Vector3d.new(0,1,0)]
         line2 = [Geom;;Point3d.new(0,10,0), Geom;;Point3d.new(20,10,0)]
         # This will return the point (10,10,0).
         line3 = [Geom;;Point3d.new(10,0,0), Geom;;Vector3d.new(1,0,0)]
         pt2 = Geom.intersect_line_line(line2, line3)
         # This will return nil, as the lines are parallel to each other.
        πŸ€“
        I'm not here much anymore.
        • s_k_e_t_c_h_yS
          s_k_e_t_c_h_y
          Thanks Dan,
          That makes sense. I see that the way the function operates however isn't what I was after. The function as it stands turns the lines into infinite rays defined by the line's two points and then checks if the infinite rays intersect. I just want to check if the line segments bounded by the pairs of points intersect.
          I'm muddling through implementing this now, unless you know of an existing coded examples. There are 5 cases to check for
          1. Parallel Lines
          2. Normal Intersection within line segments
          3. Intersection, but outside limits defined by line segment points
          4. No intersection at all
          5. Lines are coincident (intersection is a line, not a point)
          Sincerely, Paul.
          • Dan RathbunD
            Dan Rathbun
            The function as it stands turns the lines into infinite rays defined by the line's two points and ...
            In SketchUp lines are infinite, ... edges are not.
            You might try using bounding boxes around your "segemnts"...
            see API Geom::BoundingBox#intersect()
            πŸ’­
            • s_k_e_t_c_h_yS
              s_k_e_t_c_h_y
              Thanks again Dan,
              I'll see what I can come up with =).
              • s_k_e_t_c_h_yS
                s_k_e_t_c_h_y
                Not the most mathematically efficient I think, but this will do for now...
                https://groups.google.com/forum/#!topic/sketchupruby/2y8fU2wMZYo
                • S
                  slbaumgartner
                  If you have two points p1 = [x1,y1,z1] and p2 = [x2,y2,z2] the line passing through them is given by
                  [x,y,z] = p1 + k(p2-p1)
                  The segment of the line between the two points is for 0.0 <=k <= 1.0
                  So, if intersect_line_line returns a point (meaning that your two lines intersected), you just have to test that the intersection point satisfies the equation above for a k in the allowed range. It will necessarily be the same k for x, y, and z.
                  • s_k_e_t_c_h_yS
                    s_k_e_t_c_h_y
                    Ah,
                    Good point sl. I used a similar test for a line-plane intersection test.
