    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    From string to not a string
    9 Posts 2 Posters 2.2k Views 2 Watching
    • renderizaR Offline
      renderiza
      I have this problem where I have a string that I want to use as a line of code(not sure what to call it).
      Here is my example...
      sumx = "v[0].position.x + v[1].position.x + v[2].position.x"
      I want sumx to solve that math equation...Is this possible
      model = Sketchup.active_model
      ents = model.active_entities
      sel = model.selection
      faces = sel.grep(Sketchup;;Face)
      @addx = ["v[0].position.x"]
      @addy = ["v[0].position.y"]
      @addz = ["v[0].position.z"]
      model.start_operation('csplit')
        faces.each do |face|
          v = face.vertices
          num = v.length
          i = 1
          while i < num  do
            @addx << " + v[#{i}].position.x"
            @addy << " + v[#{i}].position.y"
            @addz << " + v[#{i}].position.z"
            i += 1
          ax = @addx * ","
          sumx = ax.delete ","
          ay = @addy * ","
          sumy = ay.delete ","
          az = @addz * ","
          sumz = az.delete ","
          cx = sumx # v[0].position.x + v[1].position.x + v[2].position.x ...
          cy = sumy # v[0].position.y + v[1].position.y + v[2].position.y ...
          cz = sumz # v[0].position.z + v[1].position.z + v[2].position.z ...
          px = cx / num
          py = cy / num
          pz = cz / num
          v.each do |vertex|
            p1 = [px, py, pz]
            p2 = vertex
            line = ents.add_line p1,p2
        sel.clear
      model.commit_operation
      Thanks!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        renderiza
        Yay! ๐Ÿ˜
        Here is updated code...
            @addx.clear
            @addy.clear
            @addz.clear
            v = face.vertices
            num = v.length
            i = 1
            while i < num  do
              i += 1
            ax = @addx * ","
            ay = @addy * ","
            az = @addz * ","
            cx = eval("#{sumx}") # v[0].position.x + v[1].position.x + v[2].position.x
            cy = eval("#{sumy}") # v[0].position.y + v[1].position.y + v[2].position.y
            cz = eval("#{sumz}") # v[0].position.z + v[1].position.z + v[2].position.z
            px = cx / num
            py = cy / num
            pz = cz / num
            v.each do |vertex|
              p1 = [px, py, pz]
              p2 = vertex
          sel.clear
        If you think the code can improve please let me know! ๐Ÿ‘
        • Dan RathbunD Offline
          Dan Rathbun
          Lines 5,6,7,15,16 & 17 refer to array reference v before the reference is made.
          I'm not here much anymore.
            renderiza
            Will this cause problem even if v on lines 5,6,7,15,16 & 17 is part of a string and not a variable?
            Thanks!
              Dan Rathbun
              When you ned to have an index var,... replace:
                  v = face.vertices
                  num = v.length
                  i = 1
                  while i < num  do
                    i += 1
              ... with this (remember that module Enumerable is mixed into class Array) :
                  v = face.vertices
                  v.each_with_index {|vert,i|
                Dan Rathbun
                NO.. you are correct. They are just a string char at that point.
                So my mistake. (you got me) ๐Ÿ˜ฎ
                  renderiza
                  My life is complete!!! ๐Ÿคฃ
                      v = face.vertices
                  That is great! With your suggestion I now don't need to start with an array that has a value!
                  @addx = []
                  @addy = []
                  @addz = []
                      @addx.clear
                      @addy.clear
                      @addz.clear
                      v = face.vertices
                      num = v.length
                      ax = @addx * ","
                      ay = @addy * ","
                      az = @addz * ","
                      px = cx / num
                      py = cy / num
                      pz = cz / num
                      v.each do |vertex|
                        p1 = [px, py, pz]
                        p2 = vertex
                    sel.clear
                  I appreciate your help as always Dan!!! ๐Ÿ’š
                    Dan Rathbun
                    String manipulation is quite slow in Ruby.
                    How about doing it with no strings?
                      def csplit()
                            sum = Geom;;Point3d.new(0,0,0)
                            verts = face.vertices
                            n = verts.size.to_f
                            # use API Geom;;Point3d.+ instance method;
                            verts.each {|v| sum += ORIGIN.vector_to(v.position) }
                            avg = Geom;;Point3d.new( sum.x/n, sum.y/n, sum.z/n )
                            verts.each {|v| ents.add_line( avg, v ) }
                          end # each face
                      rescue => e
                        puts "Error <#{e.class.name}; #{e.message} >"
                        puts e.backtrace if $VERBOSE
                        model.abort_operation
                      else # when no errors;
                        sel.clear
                      end # csplit()
                    FIXED: (line 17) Geom::Point3d#+ cannot take a Geom::Point3d as an arg, even tho the API says it can. Replaced sum += v.position with: sum += ORIGIN.vector_to(v.position)
                    ๐Ÿ’ญ
                      renderiza
                      Dan Rathbun I can't thank you enough you sir are brilliant!
