    ComponentInstance global transformation problem
    7 Posts 2 Posters 641 Views 2 Watching
    • fuzzybroF Offline
      fuzzybro
      Hi all,
      I have a simple situation when I have 2 ComponentInstances selected in the editor and I'm making a new Component out of them. The problem is that I'm unable to calculate a proper global transformation for each instance in the definition.
      Say, I had two instances of a one definition:
      model.entities -> [inst1, inst2]
      Then I select them and make a new component, so model looks like this:
      model.entities -> [inst3]
      inst3.definition.entities -> [inst1, inst2]
      Then i simply need to go through the hierarchy to get global transformations:
      glob1 = inst3.transformation * inst1.transformation
      glob2 = inst3.transformation * inst2.transformation
      This works fine when I'm making a new component, deselect it and go through all of the entities. But everything goes wrong when the component is being active. I know that SketchUp has an edit_transformation space for all the model.active_entities but it is inst3 that is active. Inst3 is placed in the model root and the edit_transformation is an identity matrix. So I have identical inst3 transformations for both selected and deselected cases but inst1 and inst2 transformations are different in case of inst3 being selected and deselected. How do I get global transformations for inst1-2?
      OctaneRender for SketchUp Overview and Demo Version
      Latest updates, tutorials and artwork
      facebook.com/octane4sketchup
      • tt_suT Offline
        tt_su
        What code are you using to get the transformation of inst1 and 2 when inst3 is open?
        I'm not sure if I fully understand your setup and exactly what code you are using at the given time.
        • tt_suT Offline
          tt_su
          You say selected, but do you mean open?
          Selection doesn't affect transformation at all.
          • fuzzybroF Offline
            fuzzybro
            Hi Thomas,
            This instance isn't opened, at least I don't open it myself but maybe SketchUp performs some sort of similar operation while creating a new Definition, Instance and placing components into it.
            I'm using following code to get transformations of scene entities after new ComponentDefinition and Instance was created:
                @model = Sketchup.active_model
                # close all active edit sessions to prevent crashes
                while (!@model.active_path.nil?)
                  @model.close_active
                @model.selection.clear
                # recursive function to go through all of the instances
                export_component(@model.entities)
                def export_component(entities)
                  if entities.class == Sketchup;;ComponentInstance
                    return if entities.hidden? or !entities.layer.visible?
                    # remember entityID, get instance local transformation and use it somehow
                    entity_list = definition.entities
                  else
                    entity_list = entities
                  entity_list.each { |entity|
                    if entity.layer.visible?
                      export_component(entity) if !entity.hidden?
            This way I'm getting all the local transformations and the hierarchy of the model. Then I just have to go through the hierarchy and accumulate local matrices to get the global matrix as I described earlier.
            But when I try to track changes via EntitiesObserver on create new component event I get 2 calls of onElementRemoved which removes instances inst1 and inst2, 1 call of onElementAdded, which creates inst3 and 2 calls of an onElementModified - one for ComponentIstance which has been added and one for ComponentDefinition for this instance. Oddly enough, I don't get any events for inst1 and inst2 as they have been removed before creating new component but they are present in new ComponenDefinition.entities. In onElementAdded I'm getting the transformation of a newly created inst3 and getting transformations of child Instances inst1 and inst2 which are present in the definition of inst3. At this stage I'm getting completely different transformations for inst1 and inst2 which results in a wrong global transformation when I' doing the multiplication.
            I think than at onElementAdded call stage inst1 and inst2 might have not changed their matrices from model root space to inst3 local space, I'll check it in couple of minutes and report you in that.
            But the other question is why I'm failing to receive events that removed instances inst1 and inst2 have been added or modified? I'm adding an EntityObserver to a newly created definition of an inst3 but don't receive any messages. I guess that I could use these events to get a proper matrices of a newly created inst1 and inst2 in the inst3 space.
            • fuzzybroF Offline
              fuzzybro
              hmmm.. something goes wrong, I can reproduce this behaviour only in half of the runs.. please, never mind this message till I'll figure out the problem.
              Cheers,
              V.
              • fuzzybroF Offline
                fuzzybro
                False alarm - it was a bug in my code. Sorry about that, everything works like a charm.
                • tt_suT Offline
                  tt_su
                  πŸ‘ πŸ‘
