    How to get Model Entities change event once?
    8 Posts 2 Posters 859 Views 2 Watching
    • fuzzybroF Offline
      fuzzybro
      Hello all,
      I'm trying to track if faces located in the model node had been modified (i.e. model.entities collection has been changed). I can track changes via EntitiesObserver but I'm receiving too many calls. It would be just great to get only one event telling that model itself or model.entities had changed. Is there a way to do this?
      Regards,
      Bro
      [OctaneRender for SketchUp Overview and Demo Version(http://sketchucation.com/click.php?url)]
      Latest updates, tutorials and artwork
      facebook.com/octane4sketchup
      • Dan RathbunD Offline
        Dan Rathbun
        Keep yourself a flag variable linked to the model (use the model's object id as a hash key,) and the value would be boolean.
        use the boolean value within your observer callbacks as a conditional expression:
        @changed = {}
        def onElementAdded( model )
          unless @changed[ model.object_id ]
            # DO SOMETHING HERE
            @changed[ model.object_id ]= true
        I'm not here much anymore.
        • fuzzybroF Offline
          fuzzybro
          oddly enough, I don't see a proper observer which corresponds to def onElementAdded(model). Which one should I use? EntitiesObserver? I've noticed that PagesObserved also has a onElementAdded callback, but like EntitiesObserver it throws 2 variables: entities and entity.
            Dan Rathbun
            Sorry wrote that in a hurry... I'll simplify a bit:
            module Fuzzy
              class EntsSpy < Sketchup;;EntitiesObserver
                attr_writer( ;changed ) # makes a changed=() method
                def changed?()
                  @changed
                def initialize( model )
                  @changed = false
                def onElementAdded( entities, entity )
                  unless changed?
                    # DO SOMETHING HERE
                    @changed = true
              end # class
              class AppSpy < Sketchup;;AppObserver
                def onNewModel( model )
                  model.entities.add_observer( EntsSpy.new(model) )
                def onOpenModel( model )
              end # class AppSpy
              Sketchup.add_observer( AppSpy.new )
            end # Fuzzy namespace
            • fuzzybroF Offline
              fuzzybro
              Thanks for the detailed answer, but I'm afraid that won't work properly: once a model is opened the @changed flag will be set to 'false' which is good, but when one will change model.entities it will get to the "# DO SOMETHING HERE" section only once. To set @changed to 'true' again I'll have to open/create a new model, but I need to track if this very model is changed per event. I guess it wont be possible to track the creation of new faces/instances in the model.entities that way. Please correct me if I'm wrong.
                Dan Rathbun
                The logic above is an example.
                You are free to change the logic, add conditional statements, to reset the @changed variable to false or true, depending upon conditions, in whatever callback you need to.
                I am just trying to give you some ideas, ... not write the plugin for you.
                  Dan Rathbun
                  BTW... the model has an internal modification flag, that you can access via model.modified?
                  This flag can get reset by the user if they undo all operations in a session (on the undo stack.)
                  • fuzzybroF Offline
                    fuzzybro
                    Thanks, Dan!
                    Your idea worked out very well using "onTransactionCommit" event of the Model Observer. On every commit event I simply reset the "changed" flag and then do the rest as you proposed.
