    Scenes not behaving correctly?!?
    3 Posts 2 Posters 413 Views 2 Watching
      agamemnus
      I created some code to render a helicopter. Unfortunately, for some blasted reason, most of the scenes are not being rendered correctly. Help!
      Edit: ok, never mind. I added "view.camera = pages.selected_page.camera" .. that seemed to fix things. That's pretty odd that the new camera target isn't being copied. Is it a Sketchup 8 bug?
      Fixed file:
      require 'sketchup.rb'
      module Render_isometric
       def Render_isometric.do_render
        model = Sketchup.active_model
        pages = model.pages
        layers = model.layers
        view = model.active_view
        # Set up and get pointers to the appropriate layers.
        image_base_name = "osprey"
        scenes_extension   = ["bottom", "bottom-left", "left", "top-left", "top", "top-right", "right", "bottom-right"]
        rotation_extension = ["rotation 1", "rotation 2", "rotation 3", "rotation 4", "rotation 5", "rotation 6", "rotation 7", "rotation 8"]
        rotors_extension   = ["rotors forward", "rotors up"]
        for i in (0 .. scenes_extension.length - 1)
         pages.selected_page = pages[scenes_extension[i]]
         pages.selected_page.transition_time = 0
         pages.selected_page.delay_time = 0
         for j in (0 .. rotation_extension.length - 1)
          current_rotation_layer = layers[rotation_extension[j]]
          current_rotation_layer.visible = true
          for k in (0 .. rotors_extension.length - 1)
           current_rotors_layer = layers[rotors_extension[k]]
           current_rotors_layer.visible = true
           keys = {
            ;filename    => "c;/vehicles/" + image_base_name + "-" + scenes_extension[i] + "-" + rotation_extension[j] + "-" + rotors_extension[k] + ".png",
            ;width       => 256,
            ;height      => 256,
            ;antialias   => true,
            ;transparent => true
           view.write_image keys
           current_rotors_layer.visible = false
          current_rotation_layer.visible = false
      end #end module
      Render_isometric_menu = UI.menu("Plugins").add_submenu("Render Isometric")
      Render_isometric_menu.add_item("Do Render") {Render_isometric.do_render}
      • renderizaR Offline
        renderiza
        Can you be more specific when you say "rendered correctly" because I am not 100% sure what you mean by this. Do you mean the scene style rendering options where not updated?
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          agamemnus
          Yes... all of the camera didn't update, so the image doesn't render as intended. Had to do "view.camera = pages.selected_page.camera" to get it to work correctly.
