    X-UA-Compatible meta tag changes image button position.
    6 Posts 4 Posters 889 Views 4 Watching
    • renderizaR Offline
      renderiza
      If I use this on html for web dialog... <meta http-equiv="X-UA-Compatible" content="IE=10">
      The image I am trying to use on button is not centered anymore...why?...How can I fix this problem?
      Note: Button code: <button type="next" style="width:30px;height:30px;" id="click" value="next" onclick="next = '1'"><img src="images/next.png" alt="next"></button>
      Thanks!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        renderiza
        Adding this helped...padding:0
        Button code: <button type="next" style="width:30px;height:30px; padding:0" id="click" value="next" onclick="next = '1'"><img src="images/next.png" alt="next"></button>
        Thanks!
          Aerilius
          Native buttons have a default padding (and margin etc.) that depends on the user interface theme. Once you override such a property (like padding: 0) the button can't be rendered anymore using the theme, and it won't look native anymore. Because of that it is not a good idea to use pixel dimensions when you design dynamic interfaces that are influenced for example by the user's default fonts/sizes/buttons.
          Use only pixel dimensions if you have control over all dimensions (or specify all sizes and fonts).
          <button type="next" id="click" value="next" onclick="next = '1'"><img src="images/next.png" alt="next"></button> without width/height works fine for me. If you needed the width to align it correctly, you can use container elements instead to align all child elements horizontally/vertically or whatever.
          • jolranJ Offline
            jolran
            Can't one do a CSS reset at the begining of the css file to accomodate for that ?
            If using Jquery it might be good idea to stick with pixel dimensioning, no ?
            Since Jquery calculates most stuff based on pixels..
            edit:
            Ah, oh yeah I see your Point. And you're only referring to font-size regarding em-size?
            • tt_suT Offline
              tt_su
              The META tag will kick IE into rendering in standard mode, meaning the box model and much more will work more reliable like the rest of the browsers. That means you need to adjust some of the positioning code you use.
              Exactly what code to use depend on the scenario and layout you have. Got a small snippet?
                renderiza
                I noticed that before using paddin:0 the button had a gloss effect on the button. πŸ˜•
                I tried this and it does center the button image but then the button is too big.
                http://sketchucation.com/resources/pluginstore?pln=RND_KeyScene
                The .html file is inside the "RND_Keyscene" folder...its called "rnd_keyscene.html"
                Note: Using the paddin:0 worked ok even though that will mess the theme used for button but I can deal with that.
                Thanks!
