    Unread Posts
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    6 Posts 4 Posters 7.8k Views 4 Watching
    • mitcorbM
      mitcorb
      I don't often click on this filter. I always thought that it would display only posts with zero replies. However, not today. Many have at least 5 replies. Just an observation. I generally click on Active Topics.
      (Move this if it is in the wrong area.)
      • BoxB
        I think you'll find it means posts Unread by you.
        • KrisidiousK
          Krisidious
          True... All posts you have not seen.
          By: Kristoff Rand
          • mitcorbM
            mitcorb
            Then there is a ton of them. And thanks. Apparently I used to read everything such that only those with zero activity showed up. 😆
            • jeff hammondJ
              jeff hammond
              iirc, there used to be a filter which did show unanswered threads.. you're possibly confusing things with times past..
              (or it's equally possible that i'm the confused one 😉 )
              dotdotdot
              • mitcorbM
                mitcorb
                No, I think you are right, Jeff. Thanks.
