    Help Faking Ambient Occlusion!
    11 Posts 3 Posters 989 Views 3 Watching
    • renderizaR Offline
      renderiza
      Hi, planning to make a script that will use edge style to simulate Ambient Occlusion and would appreciate any help with the following...I am wondering what would be the best way to hide all edges that are facing outwards like in the illustration bellow. Any Ideas?
      http://s7.postimg.org/qpmb8d0sq/Sketch_Up_2013_07_20_21_13_40_39.jpg
      Thanks in Advance!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        renderiza
        Added the following code to the one above one to make script work on some solid objects that are simple but I need to find a solution that works every time. 😒
        znormal = face.normal.z
        if znormal == 1 || znormal == -1
            next
        Note: Ok the above code is too bad of an idea and will not use it at all.
          renderiza
          Hi, here is my progress so far...
          model = Sketchup.active_model
          sel = model.selection
          ents = model.active_entities
          faces = ents.grep(Sketchup;;Face)
          outer_edge = []
          faces.each do |face|
              loop = face.outer_loop
              borders = loop.edges
              outer_edge << borders
              outer_edge.flatten!
          outer_edge.each do |edge|
              status = sel.contains? edge
              if (status)
                  edge.hidden = false
                  sel.remove edge
              else
                  edge.hidden = true
                  sel.add edge
          What I need now is to find a way to hide the lines that are facing outward...Any ideas?
          Note Update: I was testing code with non solid objects only and was not aware that it doesn't work with solid objects. 😒 Need to rethink this through again...oh well! πŸ˜’
            Anton_S
            Maybe this will help: Highlight edges in profile
              renderiza
              Thank you Anton_S I will take a look at it! πŸ‘
                renderiza
                Hi, here is another WIP and I am happy with the progress so far. The following code does an ok job with vertical line and now I need to work on horizontal lines.
                Anton_S the code you posted by TIG helpd me find this "faces = edge.faces " which was very usefull so thank you. πŸ‘
                edges = ents.grep(Sketchup;;Edge)
                edges.each do |edge|
                    faces = edge.faces
                    faceone = faces.first
                    facetwo = faces.last
                    f1nx = faceone.normal.x
                    f1ny = faceone.normal.y
                    f1nz = faceone.normal.z
                    f2nx = facetwo.normal.x
                    f2ny = facetwo.normal.y
                    f2nz = facetwo.normal.z
                    ## NE Vertical Lines ##
                    if f1nx == 1 and f2ny == 1
                        boundboxone = faceone.bounds
                        centerone = boundboxone.center
                        boundboxtwo = facetwo.bounds
                        centertwo = boundboxtwo.center
                        if centerone.y < centertwo.y
                            edge.hidden = true
                        else
                            edge.hidden = false
                    if f2nx == 1 and f1ny == 1
                        if centerone.y > centertwo.y
                            edge.hidden = true
                        else
                	    edge.hidden = false
                    ## SE Vertical Lines ##
                    if f1nx == 1 and f2ny == -1
                            edge.hidden = true
                        else
                            edge.hidden = false
                    if f2nx == 1 and f1ny == -1
                            edge.hidden = true
                        else
                            edge.hidden = false
                    ## SW Vertical Lines ##
                    if f1nx == -1 and f2ny == -1
                            edge.hidden = true
                        else
                            edge.hidden = false
                    if f2nx == -1 and f1ny == -1
                            edge.hidden = true
                        else
                            edge.hidden = false
                    ## NW Vertical Lines ##
                    if f1nx == -1 and f2ny == 1
                            edge.hidden = true
                        else
                            edge.hidden = false
                    if f2nx == -1 and f1ny == 1
                            edge.hidden = true
                        else
                            edge.hidden = false
                If anyone has any suggestions to better my code I am all ears...cheers!
                  renderiza
                  WIP - 7/26/2013
                  Hi, this is an update to deal with all vertical lines and it should now work 100% of the time. I still need to work of top & bottom horizontal lines but I imaging it should be easier than vertical lines. Ok here is the code so far...
                      faces = edge.faces
                      areaone = faceone.area
                      areatwo = facetwo.area
                          if centerone.y < centertwo.y and centerone.x > centertwo.x
                              edge.hidden = true
                          else
                              edge.hidden = false
                          ## N ##
                          if centerone.y < centertwo.y and centerone.x < centertwo.x
                              if areaone < areatwo
                                  edge.hidden = true
                                  edge.hidden = true
                          ## E ##
                          if centerone.y > centertwo.y and centerone.x > centertwo.x
                              if areaone > areatwo
                                  edge.hidden = true
                                  edge.hidden = true
                      if f2nx == 1 and f1ny == 1 and
                          if centerone.y > centertwo.y and centerone.x < centertwo.x
                              edge.hidden = true
                          else
                              edge.hidden = false
                          ## N ##
                                  edge.hidden = true
                                  edge.hidden = true
                          ## E ##
                                  edge.hidden = true
                                  edge.hidden = true
                              edge.hidden = true
                          else
                              edge.hidden = false
                          ## E ##
                                  edge.hidden = true
                                  edge.hidden = true
                          ## S ##
                                  edge.hidden = true
                                  edge.hidden = true
                              edge.hidden = true
                          else
                              edge.hidden = false
                          ## E ##
                                  edge.hidden = true
                                  edge.hidden = true
                          ## S ##
                                  edge.hidden = true
                                  edge.hidden = true
                              edge.hidden = true
                          else
                              edge.hidden = false
                          ## W ##
                                 edge.hidden = true
                                 edge.hidden = true
                          ## S ##
                                edge.hidden = true
                                edge.hidden = true
                              edge.hidden = true
                          else
                              edge.hidden = false
                          ## W ##
                                  edge.hidden = true
                                 edge.hidden = true
                          ## S ##
                                edge.hidden = true
                                edge.hidden = true
                              edge.hidden = true
                          else
                              edge.hidden = false
                          ## W ##
                                  edge.hidden = true
                                  edge.hidden = true
                          ## N ##
                                  edge.hidden = true
                                  edge.hidden = true
                              edge.hidden = true
                          else
                              edge.hidden = false
                          ## W ##
                                  edge.hidden = true
                                  edge.hidden = true
                          ## N ##
                                  edge.hidden = true
                                  edge.hidden = true
                      ## Edges with more than three faces ##
                      if faces[2]
                          edge.hidden = false
                      ## Edges with one face ##
                      if faces[1] == nil
                          edge.hidden = true
                    renderiza
                    Hi, this is another attempt and it seems to be working quite well with the test I have made so far. I am now wondering how to make the code work with faces that are on an angle in respect to the xyz axis. πŸ˜•
                    If anyone has a clue I am all ears...here is the code so far
                        faces = edge.faces
                    	## ZN Top Horizontal Lines ##
                    	if f1nz == 1 and f2ny == 1
                    		if centerone.z > centertwo.z and centerone.y < centertwo.y
                               edge.hidden = true
                            if centerone.z < centertwo.z and centerone.y < centertwo.y
                    			edge.hidden = true
                    		if centerone.z > centertwo.z and centerone.y > centertwo.y
                               edge.hidden = true
                    	if f2nz == 1 and f1ny == 1
                    		if centerone.z < centertwo.z and centerone.y > centertwo.y
                                edge.hidden = true
                    			edge.hidden = true
                                edge.hidden = true
                    	## ZE Top Horizontal Lines ##
                    	if f1nz == 1 and f2nx == 1
                    		if centerone.z > centertwo.z and centerone.x < centertwo.x
                                edge.hidden = true
                            if centerone.z < centertwo.z and centerone.x < centertwo.x
                    			edge.hidden = true
                    		if centerone.z > centertwo.z and centerone.x > centertwo.x
                                edge.hidden = true
                    	if f2nz == 1 and f1nx == 1
                    		if centerone.z < centertwo.z and centerone.x > centertwo.x
                                edge.hidden = true
                    				edge.hidden = true
                                edge.hidden = true
                    	## ZS Top Horizontal Lines ##
                    	if f1nz == 1 and f2ny == -1
                               edge.hidden = true
                    			edge.hidden = true
                               edge.hidden = true
                    	if f2nz == 1 and f1ny == -1
                                edge.hidden = true
                    				edge.hidden = true
                                edge.hidden = true
                    	## ZW Top Horizontal Lines ##
                    	if f1nz == 1 and f2nx == -1
                                edge.hidden = true
                    			edge.hidden = true
                                edge.hidden = true
                    	if f2nz == 1 and f1nx == -1
                                edge.hidden = true
                    			edge.hidden = true
                                edge.hidden = true
                    	## ZE Bottom Horizontal Lines ##
                    	if f1nz == -1 and f2nx == 1
                                edge.hidden = true
                    			edge.hidden = true
                                edge.hidden = true
                    	if f2nz == -1 and f1nx == 1
                                edge.hidden = true
                    			edge.hidden = true
                                edge.hidden = true
                    	## ZN Bottom Horizontal Lines ##
                    	if f1nz == -1 and f2ny == 1
                                edge.hidden = true
                    			edge.hidden = true
                                edge.hidden = true
                    	if f2nz == -1 and f1ny == 1
                                edge.hidden = true
                    			edge.hidden = true
                                edge.hidden = true
                    	## ZW Bottom Horizontal Lines ##
                    	if f1nz == -1 and f2nx == -1
                                edge.hidden = true
                    			edge.hidden = true
                                edge.hidden = true
                    	if f2nz == -1 and f1nx == -1
                                edge.hidden = true
                    			edge.hidden = true
                                edge.hidden = true
                    	## ZS Bottom Horizontal Lines ##
                    	if f1nz == -1 and f2ny == -1
                                edge.hidden = true
                    			edge.hidden = true
                                edge.hidden = true
                    	if f2nz == -1 and f1ny == -1
                                edge.hidden = true
                    			edge.hidden = true
                                edge.hidden = true
                                edge.hidden = true
                            ## N ##
                                    edge.hidden = true
                                    edge.hidden = true
                            ## E ##
                                    edge.hidden = true
                                    edge.hidden = true
                                edge.hidden = true
                            ## N ##
                                    edge.hidden = true
                                    edge.hidden = true
                            ## E ##
                                    edge.hidden = true
                                    edge.hidden = true
                                edge.hidden = true
                            ## E ##
                                    edge.hidden = true
                                    edge.hidden = true
                            ## S ##
                                    edge.hidden = true
                                    edge.hidden = true
                                edge.hidden = true
                            ## E ##
                                    edge.hidden = true
                                    edge.hidden = true
                            ## S ##
                                    edge.hidden = true
                                    edge.hidden = true
                                edge.hidden = true
                            ## W ##
                                   edge.hidden = true
                                   edge.hidden = true
                            ## S ##
                                  edge.hidden = true
                                  edge.hidden = true
                                edge.hidden = true
                            ## W ##
                                    edge.hidden = true
                                   edge.hidden = true
                            ## S ##
                                  edge.hidden = true
                                  edge.hidden = true
                                edge.hidden = true
                            ## W ##
                                    edge.hidden = true
                                    edge.hidden = true
                            ## N ##
                                    edge.hidden = true
                                    edge.hidden = true
                                edge.hidden = true
                            ## W ##
                                    edge.hidden = true
                                    edge.hidden = true
                            ## N ##
                                    edge.hidden = true
                                    edge.hidden = true
                        if faces[2]
                            edge.hidden = false
                        if faces[1] == nil
                            edge.hidden = true
                        ## Edges inside face ##
                        if f1nz == 1 and f2nz == 1
                            edge.hidden = true
                        if f1nz == -1 and f2nz == -1
                            edge.hidden = true
                        if f1nx == 1 and f2nx == 1
                            edge.hidden = true
                        if f1nx == -1 and f2nx == -1
                            edge.hidden = true
                        if f1ny == 1 and f2ny == 1
                            edge.hidden = true
                        if f1ny == -1 and f2ny == -1
                            edge.hidden = true
                      renderiza
                      If anyone is interest I updated the code above with much better one...cheers!
                        cleblanc
                        I would be interested. Could you post the new version?
                        Thanks!
                        Chris
                          renderiza
                          I still plan to keep working on this and will post future progress. The best case scenario will be to make it work on faces that have angle...so far my attempts have failed in solving this but will keep trying.
