    Failed saving image on plugin directory. (solved)
    3 Posts 1 Posters 362 Views 1 Watching
    • renderizaR
      renderiza
      Is there a way to save image inside the folder in plugin directory specified in code?
      I can save in folder outside plugin directory but not sure what folder dir is compatible with MAC and WIN. Only way is to call File.dirname(FILE)...any ideas?
      @@path = File.dirname(__FILE__) # this plugin's folder
      @@export_files = File.join(@@path, '/ExportFiles/')
      if params['antialias'].to_s == "true"
      @anti = true
      else
      @anti = false
      if params['transparent'].to_s == "true"
      @trans = true
      else
      @trans = false
      keys = {
      ;filename => "#{@@export_files}write_image.#{params['sel_type'].to_s}",
      ;width => params['getwidth'].to_i,
      ;height => params['getheight'].to_i,
      ;antialias => @anti,
      ;compression => 0.9,
      ;transparent => @trans
      model = Sketchup.active_model
      view = model.active_view
      view.write_image keys
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • renderizaR
        renderiza
        Interesting... When I use UI.savepanel and find that folder on plugin directory I can see the images but with a lock icon on the corner. If I browse that folder normally I don't see anything inside.
        • renderizaR
          renderiza
          Doing some research I found this post by TIG and it was pretty much what I was looking for.
          http://sketchucation.com/forums/viewtopic.php?p=281017#p281017
          Thanks!
