    How to check syntax without executing
    8 Posts 3 Posters 901 Views 3 Watching
    • A
      Anton_S
      Once again, it's me with more questions...
      Lets say I have this code:
      <span class="syntaxdefault">script </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"<br />hello = 'yo bro'<br />Sketchup.active_model.entities[0].material = 'red' # Assume entities[0] is an existing group<br />fgsdjhkjdf<br />"<br /><br /></span><span class="syntaxdefault">begin<br />  eval</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">script</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">rescue<br />  puts </span><span class="syntaxstring">'you got some errors there'<br /></span><span class="syntaxdefault">end</span>
      What happened:
      local var hello created
      entities[0] material changed to red
      syntax error
      What I want to do is try to check for syntax error without executing it, meaning
      not creating a local variable 'hello', and avoiding coloring the group.
      One potential solution is here: http://troessner.wordpress.com/2011/03/15/check-ruby-code-syntax-without-executing-it/
      I could call it this way: catch(:x) { eval(script) }
      This will avoid creating the local variable, but the group will be colored anyways.
      Is there a way to just check for syntax without executing anything?
      • thomthomT
        No sure about checking syntax without executing... but I don't understand why you are using eval()?
        What is the core of the question here? You want to revert any changes your script does if it runs into errors?
        <span class="syntaxdefault"><br />begin<br />&nbsp;&nbsp;Skethup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'FooBar'</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;...&nbsp;do&nbsp;magic&nbsp;stuff&nbsp;here&nbsp;...<br />&nbsp;&nbsp;#&nbsp;Any&nbsp;errors&nbsp;will&nbsp;be&nbsp;cached&nbsp;and&nbsp;aborted,&nbsp;reverting&nbsp;the<br />&nbsp;&nbsp;#&nbsp;model&nbsp;changes.<br />&nbsp;&nbsp;</span><span class="syntaxdefault">Skethup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br /></span><span class="syntaxkeyword">catch<br />&nbsp;&nbsp;</span><span class="syntaxdefault">Skethup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">abort_operation<br />&nbsp;&nbsp;raise&nbsp;</span><span class="syntaxcomment">#&nbsp;Re-raise&nbsp;the&nbsp;error.<br /></span><span class="syntaxdefault">end<br /></span>
        • A
          Anton_S
          I'm trying to modify SP3.2, so that it handles errors well, yet I do know eval() is slow.
          My question wasn't clear, I just didn't know what I was actually trying to do there. 😒 😳 What I was asking was to check Syntax errors, which are like an if statement without an end or odd number of brackets... The eval already raises immediately, if there is a syntax error. So, anyways, I got it figured out 😆
          Thanks 💚
          • thomthomT
            You know you can catch SyntaxError specifically, right?
            begin
              eval('blah!')
            catch SyntaxError
              puts "eeek!"
            • A
              Anton_S
              @thomthom said:
              > begin
              >   eval('blah!')
              > catch SyntaxError
              >   puts "eeek!"
              > end
              Doesn't work!
              catch is not like rescue or ensure. You can't write it that way.
              See here what actually catch is: http://www.ruby-doc.org/core-2.0/Kernel.html#method-i-catch
              But I did got it figured out.
              The eval checks for the syntax errors first:
              begin
                eval('Sketchup.active_model.entities[0].material = 'green'; if true then')
              rescue
                puts 'Error'
              In the result it will puts 'Error', without setting group's material green because eval checks for the correct syntax first, and then executes the script.
              • danielbowringD
                danielbowring
                begin
                > rescue
                >   puts 'Error'
                > end
                That is probably going the be the best available approach (an AST would be nicer, but there isn't one available in SketchUps Ruby).
                def self.get_syntax_errors(code)
                    code = "begin\n#{code}\nend if false"
                    begin
                        eval(code)
                    rescue SyntaxError => e
                        return e
                    return nil
                Note that depending how you use this, you could introduce a security flaw. Imagine if I sent the following code to get_syntax_errors
                    require 'fileutils'
                    FileUtils.rm_rf('/')
                begin
                    puts "This will not run!
                And then put the file up for download somewhere
                • A
                  Anton_S
                  Thanks Danial, that's some nice script, you have 👍
                  Adding begin #{code} end if false does the trick
                  • thomthomT
                    catch was supposed to be rescue in my snippet. I was language confused. :s
