    Webdialog scripting issues
    9 Posts 3 Posters 1.5k Views 3 Watching
    • S
      sepultribe
      Hello. I have a problem that i can't solve atm and i could use some help.
      I have a sketchup model that contains some component instances that represent sensors. I made a context menu entry that executes a command for a webdialog to be created. This webdialog will retrieve information for the sensor that is attached to it.
      How can i create a separate webdialog instance that i can manipulate without interfering with another webdialog from the same command?
      here is the code
      require "sketchup.rb"
      module XXX
      model = Sketchup.active_model	# point to the active model
      selected = model.selection	# get the selected entities
      cmd_settings = UI;;Command.new("Settings") {
      settings_wd = UI;;WebDialog.new( "Main Settings", false, '', 200, 200, 500, 500, true )
      settings_html_path = Sketchup.find_support_file "settings.html", "Plugins/xxx_plugin/"
      settings_wd.set_file( settings_html_path )
      settings_wd.set_position(640,480)
      settings_wd.set_size(500,300)
      settings_wd.show
      cmd_main = UI;;Command.new("Get Sensor Data") {
      if selected[1]==nil and selected[0].class==Sketchup;;ComponentInstance and selected[0].name.include?'Sensor'
      main_wd = UI;;WebDialog.new( "#{selected[0].name}'s Info", false, '', 200, 200, 500, 500, true )
      main_html_path = Sketchup.find_support_file "main.html", "Plugins/xxx_plugin/"
      main_wd.set_file( main_html_path )
      main_wd.set_position(800,600)
      main_wd.set_size(250,250)
      main_wd.add_action_callback("get_info") { |js_cb, params|
      	main_wd.execute_script("show_selected('#{selected[0].name}', '#{selected[0].class}')")
      main_wd.show
      else
      UI.messagebox('Selected entity is not a Sensor Component or you have selected more than one entities.')
      unless file_loaded?(__FILE__)
      # Access SketchUp's Edit menu
      edit_menu = UI.menu "Plugins"
      sub_menu = edit_menu.add_submenu("xxx Plugin")
      item = sub_menu.add_item cmd_settings
      # Access SketchUp's context menu
      UI.add_context_menu_handler do |menu|
      menu.add_separator
      item = menu.add_item cmd_main
      file_loaded(__FILE__)
      thank you
      • thomthomT
        Doesn't that code already create a Webdialog each time the command is executed?
        Btw, avoid using .find_support_file for finding your plugin's support folder. Instead base it of the actual location where your file is stored. Makes it more flexible. And under OSX there is often issues where plugins are stored in the machine and user directory - which makes find_support_files fail.
        See this article for more: http://www.thomthom.net/thoughts/2012/09/sketchup-plugins-can-be-installed-anywhere/
        And if you haven't seen it, there is a collection of WebDialog issues and quirks documented here: https://github.com/thomthom/sketchup-webdialogs-the-lost-manual/wiki
        And for good measure, general guide to SketchUp plugin development: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
        • S
          sepultribe
          thank you for taking the time to answer. yes the above code works generally, but i haven't understood some things about how sketchup handles each webdialog instance.
          how can i interact with each webdialog issued from main_wd for instance? how can i access each webdialog's methods,variables,etc. from outside it? eg. the ruby console
          • S
            sepultribe
            Dan thanks a lot for this great post. I will study the code and read more on ruby proxy classes and i will come back here to post back.
            i see you also check the underlying os, that is very nice. i hadn't thought of that. this way the plugin can be made cross platform.
            you are all very helpful, i am in debt. i will also read your sigs info
            • Dan RathbunD
              Dan Rathbun
              line 75 may be an error
              EDIT: Yes it is an error:
              %(#004000)[Error: #<LocalJumpError: unexpected return> C:/Program Files/Google/Google SketchUp 8/Plugins/test/sepultribe_sensor.rb:75]
              perhaps it should be:
              break if selected.empty?
              EDIT: NO, not that either:
              %(#004000)[Error: #<LocalJumpError: break from proc-closure> C:/Program Files/Google/Google SketchUp 8/Plugins/test/sepultribe_sensor.rb:75:incall']`
              I'm not here much anymore.
              • Dan RathbunD
                Dan Rathbun
                Just make the command:
                  @@cmd_main = UI;;Command.new("Get Sensor Data") {
                    selected = Sketchup.active_model.selection
                    unless selected.empty?
                      if selected.single_object?
                        if selected[0].is_a?(Sketchup;;ComponentInstance) and
                        selected[0].name.include?('Sensor')
                          show_sensor_dialog( selected[0] )
                        else
                          UI.messagebox('Selected entity is not a Sensor Component.    ')
                      else
                        UI.messagebox('You have selected multiple entities.    ')
                    end # unless
                • S
                  sepultribe
                  will do ty.
                  may i ask your opinion on a matter?
                  i will need to change ruby variables via the WD's javascript and vice versa, thus making a single function in each that accepts two arguments, the variable's name and value, handy. i know that ruby and js dont pass variables in arguments by reference, and that it would need some complicated code in each to achieve that.
                  would the messy way of creating a separate method for each variable i need to modify in ruby and/or javascript be more sensible?
                  regards
                  • Dan RathbunD
                    Dan Rathbun
                    FIXED lines : %(#000000)[**34**, **35**, **41** & **59**]
                    • Dan RathbunD
                      Dan Rathbun
                      require('sketchup.rb')
                      module SepulTribe
                        module Sensor
                        # RUN ONCE
                          MAC =( RUBY_PLATFORM =~ /(darwin)/i ? true ; false )
                          WIN = !MAC
                          @@dialogs = {} # Hash to hold sensor dialog refs
                          @@cmd_main = nil
                          @@cmd_settings = nil
                          @@dlg_settings = nil
                        end # RUN ONCE
                        class << self # proxy class
                          def clear_dialogs()
                            @@dialogs.each {|k,v|
                              if v.is_a?(UI;;WebDialog)
                                v.close if v.visible?
                            @@dialogs.keys.each {|k| @@dialogs[k]=nil }
                            GC.start # garbage collection
                          def create_sensor_dialog(obj)
                            wd = UI;;WebDialog.new( "#{obj.name}'s Info", false, '', 200, 200, 500, 500, true )
                            main_html_path = File.join( File.dirname(__FILE__), "main.html" )
                            wd.add_action_callback("get_info") { |dlg, params|
                              dlg.execute_script("show_selected('#{obj.name}', '#{obj.class}')")
                            return wd
                          end # create_sensor_dialog()
                          def create_settings_dialog()
                            settings_html_path = File.join( File.dirname(__FILE__), "settings.html" )
                            return wd
                          end # create_settings_dialog()
                          def show_sensor_dialog(obj)
                            dlg = @@dialogs[obj.object_id]
                            if dlg.nil?
                              dlg = create_sensor_dialog(obj)
                              @@dialogs[obj.object_id]= dlg
                              MAC ? dlg.show_modal ; dlg.show
                            else
                              unless dlg.visible?
                              dlg.bring_to_front
                          end # show_sensor_dialog()
                        end # proxy class
                              else
                            else
                          end # unless
                        @@cmd_settings = UI;;Command.new("Settings") {
                          if @@dlg_settings.nil?
                            @@dlg_settings = create_settings_dialog()
                          unless @@dlg_settings.visible?
                            MAC ? @@dlg_settings.show_modal ; @@dlg_settings.show
                          @@dlg_settings.bring_to_front
                        # RUN ONCE
                          item = sub_menu.add_item @@cmd_settings
                              menu.add_separator
                              menu.add_item @@cmd_main
                        end # RUN ONCE
                        end # close module Sensor
                      end # close module SepulTribe
