    Creating SketchUp scene from saved files using Ruby script
    11 Posts 4 Posters 2.6k Views 4 Watching
    • M
      MeAd
      Dear All,
      I want to create a sketchup file by automatically populating with locally saved 3D sketchup models using ruby script executed from command line. I also want to apply a transformation (rotation + translation) on each of the imported models and finally save the sketchup file. For example, I created two files: 'sofa.skp' and 'table.skp'. I want to load these files onto a new file 'room.skp' after rotating and translating these objects in ruby script. Any ideas?
      I tried to use model.import command (using COLLADA object files as shown below) but it requires a mouse click on SketchUp GUI to place the individual objects that makes it tedious considering the fact that the number of individual models as well as the need for automation. Thank you for your help.
      model = Sketchup.active_model
      model.import "file1.dae"
      • thomthomT
        <span class="syntaxdefault"><br />model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />definition </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">load</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> skp_file </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">tr </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">rotation</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> point</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> vector</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> angle </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_instance</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> definition</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> tr </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"></span>
        DefinitionList#load
        Entities#add_instance
        Some general info on instances and definitions in SketchUp:
        http://www.thomthom.net/thoughts/2012/02/definitions-and-instances-in-sketchup/
        General info on SketchUp plugin development:
        http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
        • M
          MeAd
          Thanks Thomthom. It works perfectly. One last question, can you save the new scene automatically (if possible without showing the SketchUp GUI)?
          I used the following command and I even could not locate the file.
          ` model=Sketchup.active_model
          definition=model.definitions.load('sofa.skp')
          tr= Geom::Transformation.translation [0, 0, 0]
          model.active_entities.add_instance(definition,tr)
          definition1=model.definitions.load('table.skp')
          tr1= Geom::Transformation.translation [0, 0, 0]
          model.active_entities.add_instance(definition1,tr1)
          Sketchup.active_model.save "c:/Desktop/room.skp"`
          • thomthomT
            Do you actually mean Scene here - as in the saved views you have in SketchUp - or simply model (which is what your code indicate).
            Are you sure you have the correct path? 'C:/Desktop' - do you really have a folder of that name?
            • M
              MeAd
              Hello Thomthom,
              Thanks for your prompt response. Just to clarify my previous question:
              I just meant simply model.
              Yes, I have the folder. In fact,I tried to save it in many folders and I could not locate it in any of the folders.
              • thomthomT
                What is the return value of Model.save ?
                • Dan RathbunD
                  Dan Rathbun
                  No you cannot run SketchUp in "headless" mode (without the GUI.)
                  BUT you CAN write a C/C++ application (and compile it,) that uses the SketchUp C++ SDK. Your application (be it a command line utility,) can create and save model files with no GUI.
                  I'm not here much anymore.
                  • thomthomT
                    ? Did he ask about that?
                    Sent from my LT25i using Tapatalk 2
                    • dukejazzD
                      dukejazz
                      by MeAd » March 19th, 2013, 8:36 pm
                      Dear All,
                      Here a ruby script executed from command line.
                      you can populate skp file with a drop down inputbox on a second moditor display then copy and paste to display one.
                      A good outline for drop down is my Plugins_loader_dj v1.6
                      I have a plugin that can helps you copy and paste to your presentation
                      2) Another_Sketchup_dj v1.6
                      3) Another_Sketchup_Plus_dj v1.6
                      that can be found here
                      http://sketchucation.com/forums/viewtopic.php?f=323&t=46688
                      projectEditor_dj 1.6
                      Copyright Feb 4, 2013
                      by DukeJazz: James Cochran
                      for (rotation + translation)
                      [Plugin] scaleGroupFloat_dj Ver 1.6.5 Feb 15, 2013by dukejazz » May 11th, 2012, 3:36 pm
                      http://sketchucation.com/forums/viewtopic.php?f=323&t=45254
                      Copyright Feb 15, 2013
                      DukeJazz: by James Cochran
                      1. Another_Sketchup_dj v1.6
                      2. Another_Sketchup_Plus_dj v1.6
                      • M
                        MeAd
                        Thanks Thomas. As you suggested, I used the model.save status to see if it is saved correctly and I found out that it was not. Somehow I saw unintentional character in the command and removed it. Now, everything is working.
                        Now, whenever I run the ruby script from the command line, it automatically save it as .skp. However, every time I run the ruby script, it opens a new SketchUp GUI, which i am not fond of since I am creating many models. My very last question, is it possible to perform the task without opening any SketchUp GUI?
                        Thanks a bunch Thomas.
                        • M
                          MeAd
                          Thank you all for your help. 👍 👍
