    Get_element_value issue (on Mac)
    14 Posts 4 Posters 2.9k Views 4 Watching
    • Didier BurD
      Didier Bur
      Hi all,
      I'm puzzled with this:
      I'm using a WebDialog to get some data from the user, in this case a project name.
      Everything works OK on PC, but on Mac "get_element_value returns a void string "".
      Anyone encountered this before ? (I didn't find anything related to this issue on this forum, maybe I missed something ?)
      in the webdialog method:
      @args={}
      @project_dialog.add_action_callback("main_dlg_ok") { |d, p|
           @args["projectName"] = d.get_element_value("projectName")
           # other stuff goes here...
           @project_dialog.close
      in the HTML file:
      <input size="20" form="Project" name="projectName" value="Nom du projet" type="text">
      DB
      • Dan RathbunD
        Dan Rathbun
        Try using id instead of name, even though both work the same under MSIE, under Webkit things may require using the id attribute. (This could be because of a strict DOCTYPE ?)
        <input size="20" form="Project" id="projectName" value="Nom du projet" type="text">
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          If that does not work.. it is likely an sync issue. The Ruby statements continue to be executed and the one that closes the dialog executes before the value gets returned.
          Set up an javascript onChange event for the input, that fires a specific Ruby callback to set the projectName hash member.
          HTML
           value="Nom du projet" type="text" onChange="project_name_to_ruby(this.value);">
          and JS:
          function project_name_to_ruby(proj) {
            window.location = "skp;set_project_name@" + proj;
          And on the Ruby-side:
          @project_dialog.add_action_callback("set_project_name") { |d, p|
            @args["projectName"] = p.strip
          • Didier BurD
            Didier Bur
            Thanks Dan, I'll try that asap πŸŽ‰ and let you know which solution works...
            DB
            • Didier BurD
              Didier Bur
              Hi Dan,
              First option (using "id" instead of "name") does'nt work, so clearly this is a sync problem.
              Second option (js) works, but what a complex coding for such a simple task... Mac sucks πŸ‘Ž
              DB
              • thomthomT
                Syncing issue exists only when you send data from JavsScript to Ruby using the window.location = 'skp:......' protocol.
                get_element_value is synchronous.
                What triggers the "main_dlg_ok" callback? Is the HTML fully ready at that point?
                • Didier BurD
                  Didier Bur
                  Hi TT,
                  It's a "OK" button:
                  <input type ="button" value="Valider" onClick="window.location='skp;main_dlg_ok'">
                  I don't exactly know if the HTML is ready at this point, because it is written "on demand", just after the user clicks on the icon that launches the WebDialog
                  Regards,
                  DB
                  • jolranJ
                    jolran
                    A longshot.
                    I noticed some difference in behaviors for button click events if assigning them inside the JS doc.ready functions instead of in the html tag.
                    I'm using Jquery though..
                    • thomthomT
                      I don't suppose to have a complete reproducible case?
                      • jolranJ
                        jolran
                        Who me ?
                        No, I already sent you code to poke around for fouls πŸ˜‰
                        But you can just try putting onclick events in the html tag and see if you notice they missfire occasionally. (Compared to as having a function in the 'doc.ready' that binds the clickevent for the button that is.)
                        I dont not know why that happend for me. I just cared to mention it as a variable to test since I got the impression Didier was worried the html wasent ready.
                        • jolranJ
                          jolran
                          Ahh... Forget my suggestion.
                          Had a typo in the code that made the clickevent fail in a certain condition.
                          Thomthom probably knew that something fishy was going on.
                          So anyone have the solution to this syncing problem for Mac? I'm interested as well..
                          Didier. Did you make it work ?
                          • Didier BurD
                            Didier Bur
                            I made it work the lazy way: data in the dialog box is saved in a global variable 😳 , so when the dialog closes it can be retrieved without js script or anything...
                            $args={}
                            			$args["nomProjet"] = d.get_element_value("nomProjet")
                                                    $args["auteur"] = d.get_element_value("auteur")
                            Thanks everybody for your help
                            DB
                            • jolranJ
                              jolran
                              That's one way of doing it. πŸ˜„
                              • thomthomT
                                Surely an instance variable will work just as well? Avoiding the risk to collision of global variables - especially with a common variable name such as args.
