    Add_polygon seems very slow
    11 Posts 4 Posters 570 Views 4 Watching
      dacastror
      Hi guys, I want to ask if there is something faster than add_polygon, I see much difference when I commented the lines 15 and 16. with this pair of lines becomes 130 times slower!
      seems that the command "add_poligon" does something very complicated or is very inefficient or I'm using it in the wrong way
      in the following code I make a rectangle subdivided;
      t = Time.now
      lados_x = 100
      lados_y = 100
      mesh = Geom;;PolygonMesh.new((lados_x+1)*(lados_y+1),lados_x*lados_y)
      l1 = []
      for i in 0..lados_x
         l1[i] = Geom;;Point3d.new(i,0,0)
      l2 = []
      for j in 1..lados_y
         for k in 0..lados_x
            l2[k] = Geom;;Point3d.new(k,j,0)
         for i in 0..lados_x-1
            #mesh.add_polygon l1[i], l1[i+1], l2[i+1]
            #mesh.add_polygon l1[i], l2[i+1], l2[i]
         l1 = l2.clone
      =begin
      ent=Sketchup.active_model.active_entities
      grupo = ent.add_group
      entities = grupo.entities
      entities.fill_from_mesh mesh, true, 0
      =end
      Time.now-t
      Does anyone have any suggestions?
      (google translator)
      • danielbowringD Offline
        danielbowring
        The problem is you are using Point3d arguments - this means each call to add_polygon needs to call add_point three times. You can add all the points beforehand and then use their index to add the polygons. This should add a significant speed boost.
        Here's the code:
        t = Time.now
        lados_x = 100
        lados_y = 100
        l1 = []
        for i in 0..lados_x
           l1[i] = mesh.add_point(Geom;;Point3d.new(i,0,0))
        l2 = []
        for j in 1..lados_y
           for k in 0..lados_x
              l2[k] = mesh.add_point(Geom;;Point3d.new(k,j,0))
           l1 = l2.clone
        puts Time.now-t
          dacastror
          !woooow this reduces the time to less than one-third! 😍
          thank you very much Daniel!
            Also, if you ever need PolygonMesh.point_index http://www.sketchup.com/intl/en/developer/docs/ourdoc/polygonmesh#point_index - don't use it. It's slow. Instead, store the point and index you get from PolygonMesh.add_point into a hash and it'll be much much faster.
            And, if you are adding the geometry to an Entities collection that has no other entities in it, use Entities.fill_from_mesh as it's faster.
              dacastror
              Thanks for the tips Thom, this will be very useful at some time
              I have a question, how can get the vertices of this surface?
                Ah, very good question. I've been struggling with that myself. Trying to compare and map based on position - but floating precision might cause problems.
                  Ok - here is a bare bone test:
                  https://gist.github.com/thomthom/5160068
                  • Dan RathbunD Offline
                    Dan Rathbun
                    In your code you have:
                    %(#008000)[# Because Geom::Point3d objects cannot be compared ...]
                    .. BUT the API overrides the ==() method for the Geom::Point3d class, that WILL test the objects co-ordinates within SketchUp's internal tolerance.
                    Also...
                    Sketchup::Vertex.position returns a Geom::Point3d
                    Geom::Point3d.x ( .y and .z) all return Length class objects, ...
                    and ALL of the comparison methods for the Length class have been overridden to use SketchUp's internal tolerance.
                    BTW, the Sketchup::Vertex class could use a wrapper:
                    class Sketchup;;Vertex
                      def ==(other)
                        return false unless other.is_a?(self.class)
                        return false unless other.position.is_a?(Geom;;Point3d)
                        self.position == other.position
                    I'm not here much anymore.
                      Dan Rathbun
                      @thomthom said:
                      ` %(#008000)[# What what if you generate a mesh, then add it to SketchUp - is there a
                      chance that SketchUp slightly adjusts the points within it's tolerance range
                      in order to merge vertices etc?]`
                      Should the general rule of thumb be to use arrays of Length objects to build Geom::Point3d objects, rather than arrays of Float objects ??
                        Ah yea - I meant to clean up that comment. It is misleading. What I actually had in mind was what happens when you use Geom::Point3d as a key in a hash - if you create a Point3d object with the exact same values the hash is different.
                          dacastror
                          thank you very much for the replies dan and Thomthom, I'll take a look at the code Thomthom experimental, to see if I can use some of this code
                          (google translator)
