    Hide Cursor Help
    6 Posts 3 Posters 871 Views 3 Watching
    • renderizaR Offline
      renderiza
      For the game I am making I want the cursor to not be visible while playing. I tryed using a transparent png file to use as a cursor but I can't make it work.
      cursor_id = nil
      cursor_path = Sketchup.find_support_file("Pointer.png", "Plugins/")
      if cursor_path
       cursor_id = UI.create_cursor(cursor_path, 0, 0)
      def onSetCursor
      puts "onSetCursor; view = " + view.to_s
        UI.set_cursor(cursor_id)
      If there is the possibility to set the position of the cursor off screen that will be even better than using a transparent png.
      Again thanks and remember I am not that good but will try my best understanding you suggestions.
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        driven
        you could try a 1px x 1px cursor?
        john
          renderiza
          Been searching and can't find a way to do this...Can u provide simple example?
          Also found that in order to move the cursor with script I need to use WINAPI..here is example: http://msdn.microsoft.com/en-us/library/ms648394%28VS.85%29.aspx
          Only problem the code there is C++ 0_0
          Anyways thanks for help.
            driven
            just did a test and the 1x1 didn't work, however
            I copied and renamed a working cursor in another plugin [ae_wiretool], then in an editor I 'cut' the image content out of the png file, now when run in SU I have no cursor...
            john
            • Dan RathbunD Offline
              Dan Rathbun
              @Rafael: ALL of the code in your first post MUST be within a custom Tool, otherwise onSetCursor() will never be called by the application engine.
              Also do not put string output calls within UI callbacks, because this will slow down SketchUp in a MAJOR way.
              I'm not here much anymore.
                renderiza
                Thank you Driven & Dan Rathbun I solved it thanks to you guys! πŸ˜„
                Note: loading my plugin as tool solved another problem without me trying and that is when you are playing the game before you could click & drag mouse and select objects which was bad but now its all fixed!
