    Edge Center
    9 Posts 2 Posters 2.6k Views 2 Watching
    • jolranJ
      jolran
      Hi.
      Edge.bounds.center gives you the center of edge apparently.
      It IS a drawingelement(I should read the API better) so bounds could be called for it, just havent used that method before.
      It would be easier than offsetting edge.line[1] by edge.length/2 or something like that..
      It seams to be working in my code. So question is, are there any pitfalls or inconsistency one should be aware of using this method?
      I know sometimes Face.bounds.center can need project_to_plane for ex.
      But thinking about it, the center of an edge boundingbox must be center of edge regardless of position, orientation 😕
      So would edge_center = edge.bounds.center.project_to_line(edge.line[1)] be superfluous ?
      • thomthomT
        Should be yes.
        A quick loop over a set of edges where you test the two methods should let you verify.
        I'd be interested in profiling this - I used to use Geom.linear_combination for edge mid-points. But the edge bound center might be faster as it'd be less steps. But as always - everything needs to be tested.
        • jolranJ
          jolran
          Yes, me to. I totally overlooked this method. Saves a lot of typing.
          Seeing all the tests you've done all over this forum I think you are well suited for the task 😄
          • thomthomT
            <span class="syntaxdefault"><br />model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />entities </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br /><br />t </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />edges </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"Edges; #{edges.size}"<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"Edge collection; #{Time.now - t}s"<br /><br /></span><span class="syntaxdefault">t </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />mid_points1 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">  edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bounds</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">center<br /></span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"Midpoint by bounds; #{Time.now - t}s"<br /><br /></span><span class="syntaxdefault">t </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />mid_points2 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">  edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">line</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">/</span><span class="syntaxdefault"> 2 </span><span class="syntaxkeyword">)<br />}<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"Midpoint by offset; #{Time.now - t}s"<br /><br /></span><span class="syntaxdefault">t </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />mid_points3 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">  Geom</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">linear_combination</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> 0.5</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0.5</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position </span><span class="syntaxkeyword">)<br />}<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"Midpoint by linear_combination; #{Time.now - t}s"<br /></span><span class="syntaxdefault"></span>
            Edges: 474629 Edge collection: 0.437s Midpoint by bounds: 0.655s Midpoint by offset: 2.153s Midpoint by linear_combination: 1.716s
            Using bounds are clearly the fastest. And so much faster than linear_combination which I used that I got some refactoring to do.
            • thomthomT
              And 3d point results are identical.
              • jolranJ
                jolran
                Edges: 474629
                That is quite some speed increase! Relatively speaking...
                Lets just hope the method itself is accurate enough when putting it to use.
                I have been using this method last couple of hours for testing with cpoints here and there,
                and so far appears correct behavior.
                Thanks for testing 👍
                Every dirt one can polish off is good, huh?
                • thomthomT
                  Well, I did compare the results of each of the midpoints for all the 474629 edges in my test model (an imported AutoCAD drawing) and they where exactly the same.
                  • thomthomT
                    The speed difference results in that it's doing less - and all the work is done in C. While the method I had used, and your offset method, was doing more - partially in Ruby.
                    • jolranJ
                      jolran
                      Yeah, thats probably true.
                      Anyway, speed increase is always good.
                      I'll switch to this method and report back if any oddities.
                      Cheers.
