    Buying a new computer?
    149 Posts 34 Posters 71.7k Views 34 Watching
      sonder
      You folks will be very pleased with that GPU.
      • AureusA Offline
        Aureus
        And what a powerful machine I have in my possession!
        Intel Pentium Dual CPU E2220 (2.4 Ghz), 2GB DDRII RAM, 80GB Sata HDD, 19" display...who knows what graphic card...
        Do I live in the same age with you guys?... ๐Ÿ˜ž
        • soloS Offline
          solo
          Well then join us and upgrade.. ๐ŸŽ‰
          http://www.solos-art.com
          • AureusA Offline
            Aureus
            "Well then join us and upgrade.."
            From Bosnia? I don't think so. ๐Ÿ˜‰
            Well, my favourite team...OK spell-checker, my favorite team have already lost today so in order to preserve my rest I think I should leave this thread.
            64GB RAM...
            • Bob JamesB Offline
              Bob James
              @solo said:
              Send me an email and I'll forward it to my guy and he will respond directly to you with a deal under the same 'Solo deal'.
              We may be talking about two different things:
              1. it was my understanding that we could modify the Solo machine components. I would need to know what options I have
              2. I would send you an email with my intended work machine configuration to see what they could do for me on that machine.
              I'm assuming that your post quoted above is in regard to #2.
              What I also need is the information for #1
              ๐Ÿ˜„
              • soloS Offline
                solo
                ๐Ÿ˜„
                Yes both, I have options for the Computer as in my configuration and I have options for the workstation as per what you need. Anything ordered under the same "company" will be valid for a discount.
                So, Bob let me know everything you need and I will try beat any price you can get, as I'm sure we can include it in this bundle.
                • N Offline
                  numerobis
                  @solo said:
                  I have been assured that every overclocking is stressed tested for 36 hours to make sure the system is 100% stable and the company does not overclock above 4.2Ghz as they know we run our rigs for long periods and they want us to have a stable problem free rig and I agree, I will have mine clocked to 4.2Ghz by the way.
                  I think all they will do then is to set the auto overclocking to 4,2... which will be stable for all "stress testing" (which is a very unprecise definition btw.) And i think 4,2GHz should be possible with almost every 3930K without problems. That would take you or them only 3 seconds to do, BUT will normally result in higher voltages than needed and can in the case of Sandy Bridge E degrade the CPU in some cases if the VCCSA and VTT voltage is set too high. ( http://rog.asus.com/forum/showthread.php?19926-3930K-C2-Degradation )
                  I don't want to spoil the party - only to point out that "overclocking" can be done in several ways... ๐Ÿ˜‰
                  • hellnbakH Offline
                    hellnbak
                    I've always built my own computers, but I might be interested in one of these.
                    A couple questions -
                    I definitely do not want a mid-size case. I suppose I could just transfer everything to a new case but is a full-size tower an option?
                    I'm avoiding solid state drives for now, I want to let that technology cook for a while yet until their reliability is equal to the "old" drives. Can I get the OS installed on a WD 250GB Black drive? And I don't need a secondary drive, I buy WD drives when there's a good sale on the one's I like, and I have probably 13 or 14 of them set aside for future needs.
                    I probably already know the answer to this one, but does the Win 7 come on a disc, not a "recovery disc", but on it's own disc?
                    And finally, how would I find out what the system I describe would run, ball park?
                    • andybotA Offline
                      andybot
                      This is a great thread, and if I had the budget currently, I'd be very interested. However, I am thinking I will try a 2U case for the next computer I build and see about getting my render farm set up as a server rack. I already have two boxes for rendering, and my thinking is that I will quickly run out of floor space if keep adding towers... ๐Ÿ˜•
                      Steve,
                      If I may suggest, an SSD drive should be used for the OS and software, with a shadow backup of the OS written on a regular drive. SSD is significantly (very noticably) faster than a spinning disk when it comes to running software. Things just load and start instantaneously, whereas now working on a machine with a 7200RPM HDD feels sluggish.
                      • soloS Offline
                        solo
                        Steve,
                        Andy, when you are ready to buy a server rack setup, shop around first and then come to me with the best price you can get and I'll see if I can get a better deal.
                        • soloS Offline
                          solo
                          Steve,
                          Everything is customisable, so if you want a larger case no problem. I too was weary about solid state drives as I have heard too many horror stories, but as Andy suggests the advantages overide the fear as far as speed goes, and yes you can set up to shadow that drive, I was thinking of a third 1TB drive to do such a thing so if anything ever happened I could just rename that the ๐Ÿ˜„ drive and contine as nothing happened. (at least that is what I believe can be done)
                          • andybotA Offline
                            andybot
                            Thanks Pete. When I do get serious about it, I'll start another thread and would love to hear more.
                            • andybotA Offline
                              andybot
                              For backup - the simplest thing is to use the native ๐Ÿ˜„ drive/ system settings backup that comes with Win7 and you can simply restore that copy to a new SSD fairly quickly. It's also a very good idea to have a clean OS backup in case of any computer viruses. ๐Ÿค“
                              • soloS Offline
                                solo
                                Okay, so what's the deal you ask.
                                I have a page setup with the company who will be building the systems, there are 4 options as setup, these are just 4 different build ideas and you can change them as you require.
                                I am going for the second option.
                                Page Not Found | JNCS
                                JNCS (www.jncs.com)
                                **$2,605
                                JNCS Model TS1000-128-680**
                                Chassis
                                Antecยฎ 302 Chassis
                                Power Supply
                                Cooler Masterยฎ Silent Pro 850W Power Supply
                                Motherboard
                                Intelยฎ Extreme DX79SR Desktop Motherboard
                                CPU
                                Intelยฎ Coreโ„ข i7-3930K
                                Sink & Cooler
                                Gelid Tranquillo CC-TranQ-01-A 120mm CPU Cooler Rev 2
                                Memory
                                Corsair (4 x 8GB) SDRAM - 1866 MHz
                                SSD
                                Samsung 840 Pro Series MZ-7pD1228BW 2.5" 128GB SSD
                                Data Drive
                                Western Digital Caviar Black 2GB WD2002FAEX 64mb Cache SATA 6.0Gb/s
                                Video
                                EVGAยฎ Model 04G-P4-2686-KR GeForce GTX 680 Graphics Card = 1019 Mhz Core - 4GB GDDR5 - PCI-E 3.0 x16
                                DVD-RW
                                LG, Reads DVD, CD Writes DVD, CD
                                O/S
                                Microsoftยฎ Windows 7 Professional 64bit
                                Warranty
                                1 Year
                                Attached I include the prices from other builders I have used in the past to compare the deal we are getting.
                                • soloS Offline
                                  solo
                                  So as you can see we save an average of $400 on a top end rig.
                                  • hellnbakH Offline
                                    hellnbak
                                    I know that SSD's are incredibly fast compared to normal drives, but I was concerned about reliability. This was based on research I did a while back, but after doing more research this morning I find that their reliability is now comparable, and the Samsung Pro 840 series has received very high marks. So, yes, I would go with a small SSD for my C drive.
                                    As far as the full-size tower I want, I assume I could choose from a selection they have available. I don't need or want anything fancy, no neon lights or racing stripes, just something solid and well laid out, where everything is easily serviceable. It could be painted puke green for all I care, nobody's gonna see it but me. So how do I see what they have to choose from?
                                    But as far as prices for this (very nice) rig, I can't seem to find anything in this thread that really nails it down. I know it will vary according to individual setups, but what do I need to do to get a price for the setup I want?
                                    • soloS Offline
                                      solo
                                      I agree on the simple case, I purposely chose a plain case with no silly lights and sliding covers, it's not how it looks, it's how it performs.
                                      The price is in the link above, $2600 for this beast (cheaper option also available if you want a different GPU)
                                      • hellnbakH Offline
                                        hellnbak
                                        While I was composing my last post you have posted more info on prices, so that answers my last question. Thanks.
                                        • soloS Offline
                                          solo
                                          Okay, it's ready to go.
                                          If you want to modify anything then email Adam Pierce apierce@jncs.com
                                          And remember to mention either Solo or Pete Stoppel in correspondence for him to include you in the discounted deal.
                                            Are the prices they show the discounted ones?
                                            • 6
                                            • 7
                                            • 8
                                            • 3 / 8
