    Help: Exporting Sketchup Free to *.x-file
    5 Posts 3 Posters 6.0k Views 3 Watching
    • S
      schmitty782
      Hello,
      i'am modelling ships for the computer-game Virtual Sailor.
      For the game i need the model in the *.x-format (directX).
      I'am using the 3DRadexporter-Plugin for this job, but the results are not very good. It has problems to export the textures correctly:
      original texture in Sketchup:
      http://i50.tinypic.com/2ed5lrr.jpg
      textures in the game (look at the white of the name and the logo):
      http://i50.tinypic.com/33wm6gx.jpg
      Is there a other plug in or a other way for exporting the skp to x-file?
      Regards
      Christian
      • J
        Jim
        There's this one:
        http://sketchucation.com/forums/viewtopic.php?t=50152
        • soloS
          solo
          If Jim's solution does not work (as model is large I'm assuming) then upload it and I'll give it a go with a converting tool I have.
          http://www.solos-art.com
          • S
            schmitty782
            Hello & thanks for your answers!
            @ Jim: i tried tis plugin, but it freez for more than an hour. Perhaps my model is to large?
            @solo: Thank you for your offer. I have to convert more than one file. And i'am searching for a method which i can use for my next models...
            Which tool are you using? (i high-end professional toll which costs a lot of money?)
            Regards
            Christian
            • S
              schmitty782
              Hello togehter,
              the problem is still there (Sketchup to x-file)
              I try the following things:
              1.) If i use 3d-Rad-Exporter i get the problem with the textures, have a look:
              http://i44.tinypic.com/b4t91u.jpg
              2.) If i use xExporter i have the same problem like the 3d-Rad-Exporter.
              3.) If i use ZbylsXExporter, the Plugin break down.
              Have anyone a idea? Could it be a general texture-problem of Sketchup, or is it a exportproblem?
              By the way, i'am using Sketchup Make
              Regards
              Christian
