    Newbie to Ruby
    5 Posts 4 Posters 357 Views 4 Watching
    • daveedwardsD Offline
      daveedwards
      I've been with SU since nearly day one, but new to Ruby.
      I'm trying simply to create geometry based on points from selected geometry. I know how to parse through select objects, but can't seem to figure out how to extract the Start and End points of a selected Edge. Not sure this is the correct subforum for this. TIA!
      David William Edwards
      • Dan RathbunD Offline
        Dan Rathbun
        Assuming the reference to the Edge is e1
        sp = e1.start.position ep = e1.end.position
        I'm not here much anymore.
          <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;Assuming&nbsp;a&nbsp;single&nbsp;edge&nbsp;is&nbsp;selected<br /></span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />edge&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">start_point&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />end_point&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br /></span>
          API Reference
          http://www.sketchup.com/intl/en/developer/docs/ourdoc/selection
          http://www.sketchup.com/intl/en/developer/docs/ourdoc/edge
          • O Offline
            Obryan
            I have been using Sketchup for a long time but I cant figure out how to load Solid Inspector.
            It seem that I have loaded Simple Installer correctly because I can see it in the plugins drop down menu. I believe I installed solid inspector the same way and I can see it in library/application support/sketchup/plugins.
            (see attached screen shot)
            However, it does not appear in the plugins drop down menu.
            When I open Sketchup I get this error message:
            Error Loading File tt_solid_inspector-2.rb
            no such file to load -- TT_Lib2/core.rbError Loading File tt_solid_inspector.rb
            I am using a Mac OSX 10.6.8 with Snow Leopard and Sketchup 8.
            I have some complex components which I cant figure out how to make solid so I would really appreciate some help.
            Thank you in advance.
            Sean
              Dan Rathbun
              Did you ALSO install TT_Lib2 ?????????????
              Obviously solid inspector has a library dependancy on TT_Lib2.
              Did you read the solid inspector post for dependancies, and install all those needed ?
