    Ruby get slope of a surface
    8 Posts 5 Posters 685 Views 5 Watching
    • O Offline
      ordoumpozanis
      Hi all,
      I am new to Ruby and I' like so help. I am trying to write a code that gives the slope (angle between the blue line and and the the face normal) of a roof but i cannot get it work
      I am using this code but does not work
      norm.angle_between
      slope = norm.angle_between(Geom::Vector3d.new(0,0,1)).radians
      any help ?
      thanks
        Aerilius
        Hi, it's simple:
        "it doesn't work" = "it doesn't do what I expected"
        Then what do you expect?
        Your example worked with that face:
        face = Sketchup.active_model.entities.add_face(ORIGIN, [0,1,0],[1,1,1],[1,0,1]).reverse
        slope = face.normal.angle_between(Z_AXIS).radians
        >> 45.0
        Please make test cases (and define for each an expected result), then test each and then you either correct the code or the test case.
        • O Offline
          ordoumpozanis
          Aerillus Thanks for the reply πŸ˜„
          If I understant well at the first line you design a surfae and at the second one you get the slope..
          when I am trying to apply the second commant
          on a design face i get a nill value
          what do I make Wrong here ?
          • Chris FullmerC Offline
            Give us the full code then, instead of the snippet you provided. If your code isn't working, then it might have something to do with how you are retrieving the face object. Are you sure you're actually referencing a face for example?
            All my Plugins I've written
              Code and sample model.
              Whenever I get unexpected result I ensure I inspect the values of the variables I use - to make they they contain the values I expect them to be. Often the error can be in another place.
              • O Offline
                ordoumpozanis
                The code that i am trying to apply to get the slope of a model's surfaces is the following
                <span class="syntaxdefault">&nbsp;&nbsp;model</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;ss</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />&nbsp;&nbsp;faces</span><span class="syntaxkeyword">=[];&nbsp;</span><span class="syntaxdefault">ss</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">e&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">}&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">";"</span><span class="syntaxkeyword">)[-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">">"</span><span class="syntaxkeyword">)[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">norm</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal<br />&nbsp;&nbsp;&nbsp;&nbsp;slope&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">angle_between</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Z_AXIS</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">radians<br />&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;slope<br />&nbsp;&nbsp;</span><span class="syntaxkeyword">}&nbsp;</span><span class="syntaxdefault"></span>
                ok i now i have program somthing wrong but i cannot find out what πŸ˜„
                  Can you also post a model with a face where the result is incorrect? (Please also describe what is expected value.)
                  • Dan RathbunD Offline
                    Dan Rathbun
                    Are you still using SketchUp 6 Pro ?
                    There was a bug in the Geom::Vector3d#angle_between() method that was fixed sometime in the 7.x branch.
                    I'm not here much anymore.
