    Rbs weird behaviour on modules
    4 Posts 3 Posters 229 Views 3 Watching
      SR20VET
      Today I ran into this weird behaviour when scrambling my scripts into an rbs.
      Lets say I have the folowing script:
      module MyModule1
        def self.load_second_script
          Sketchup;;require 'second_script'
        end#def
      end#module
      in seconds_script.rb(s) i have:
      module MyModule1
        module MyModule2
        end#module
      end#module
      next, I do:
      MyModule1.load_second_script
      While testing with rb, this eventually gives
      MyModule1;;MyModule2
      as a valid module.
      With rbs this results in
      MyModule1;;MyModule1;;MyModule2
      Has anyone noticed this before?
      Regards
      • Dan RathbunD Offline
        Dan Rathbun
        YES. ThomThom first noticed this, and has filed a bug report.
        The error is within the Sketchup::require() method.
        To workaround, you will need to force the evaluation to occur within the TOPLEVEL_BINDING, thus:
        module MyModule1
            eval("Sketchup;;require('second_script')",TOPLEVEL_BINDING,'second_script.rbs',1)
          end#def
        end#module
        πŸ’­
        I'm not here much anymore.
          It also happens with SketchupExtension classes - where you cannot bypass the Sketchup::require call and I had to create a proxy .rb file to load the actual .rbs file.
            SR20VET
            Ok, thanks for the workaround. You should expect that no mather you use rb's or rbs's, they behave the same way...
