    It is making me mad
    9 Posts 4 Posters 904 Views 4 Watching
    • majidM Offline
      majid
      I donno what is the problem with my chrome browser, while searching pics....it only shows 1 page.
      I donno what do I must change to enable it to show more pages.
      also I've tweaked search result to have more result, but no further benefits...
        and other navigators ?
        • majidM Offline
          majid
          oooh yes, explorer is the same...
            That is not a limitation gives by your country?
            • majidM Offline
              majid
              seems you are right, as if I use proxy app, it works fine!!
              • michaliszissiouM Offline
                michaliszissiou
                Meanwhile, did you use a new modem, just saying.
                In any case, check the firewall settings on your modem first.
                It may not be your country. But it's most possibly a firewall issue.
                For instance, try without any firewall. Then, start adding it and watch what's wrong.
                I had a similar problem, a year ago. It was the modem.
                • EscapeArtistE Offline
                  EscapeArtist
                  Sounds like a filter issue. Is TOR available to you? It's a little slow, but I've used it on occasion to dodge national firewalls or to protect my anonymity.
                  https://www.torproject.org/download/download
                  • majidM Offline
                    majid
                    seems that even tor is not functioning for me.......... it remains at this situation for a long while, doing nothing
                      EscapeArtist
                      Very sorry it didn't help. It may be that the proxy is firewalled.
