    [PlugIn] 3D Printers G-Code importer/Exporter Ver0.0.9
    29 Posts 13 Posters 42.4k Views 13 Watching
      Davidfi1
      What should the next feature be?
      If you have an idea, I will be very happy to try implementing it.
        Jim
        Animate a model of a cnc machine from the gcode.
          Davidfi1
          Did you try to import CNC G-Code?
          Can you explain what was the problem?
          Do you have an idea how it should work if it was working correctly?
            dooseyboy
            i have attempted this plugin in 2013, about to try it in 8 pro.
            thought i should bring this little web app that i found recently.
            it is a gcode viewer and i was hoping to use it to view the gcode i exported from sketchup in it but it doesn't seem to be working from being exported in 2013.
            http://jherrm.github.io/gcode-viewer/
            neither of the gcode files i exported from regular sketchup files worked in the simulator. but i am keen to use this addon to use the simulation app
            • Z Offline
              zurits
              Does not work for me either; Sketchup 2013 Win7x86, thanks for for the code.
                mkultra
                2014 load fails...
                2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:38: formal argument cannot be an instance variable
                @filamentComp.entities.each { |@ent|
                C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:163: formal argument cannot be an instance variable
                IO.foreach(filename) do |@line|
                C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:183: formal argument cannot be an instance variable
                @params.map {|@var|
                C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:40:in register_extension' C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:40:in loadLastVer'
                C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:47:in <module:Fishelzon>' C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:11:in <top (required)>'
                  mctabish
                  I am also failing to load on start up. I get:
                  Error Loading File C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb
                  Error: #<SyntaxError: C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:38: formal argument cannot be an instance variable
                  C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:163: formal argument cannot be an instance variable
                  C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:183: formal argument cannot be an instance variable
                  @params.map {|@var|
                  C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:40:in register_extension' C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:40:in loadLastVer'
                  C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:47:in <module:Fishelzon>' C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:11:in <top (required)>'
                  Any resolution?
                  sketchup 2014 Win 7 x64
                  Bruce
                  • Dan RathbunD Offline
                    Dan Rathbun
                    Try making the following changes. untested
                    (Ruby v 2.0 will not allow direct references to instance variables in the block parameter list.)
                    Line 38:
                    @filamentComp.entities.each { |ent| @ent = ent
                    Line 163:
                    IO.foreach(filename) do |line| @line = line
                    Line 183:
                    @params.map {|var| @var = var
                    I'm not here much anymore.
                      sparkdaddychad
                      I know this is a couple of years old but the plugin does not appear to work with latest version of SKetchup Make. Any chance there is an updated version of this plugin anywhere? Would really love to import Gcode files into SKetchup.
                      Thanks!!
                      • 2 / 2
