    ( [ 0,0,0 ].vector_to( [ 0,0,0 ] ) ).length.mm < 0.01.mm
    6 Posts 4 Posters 280 Views 4 Watching
      Davidfi1
      is this "true" or "false"?:
      on my computer it is "false" - and I dont know why?
        Jim
        SketchUp's Length class uses some default tolerance in its comparisons - the tolerance is not documented as far as I know.
        The equality comparison on Length values uses the default tolerance that SketchUp uses for comparing lengths
        In SketchUp-land:
        > 0.01.mm == 0 #==> true
        Search the following page for "tolerance"
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/length
          Aerilius
          nullvec = Geom;;Vector3d.new(0,0,0)
          l1 = nullvec.length.mm # obviously 0 mm or 0 inch
          l2 = 0.01.mm  # 0.000393700787401575 inch
          l1 == l2
           β†’ true
          but
          0 < 0.000393700787401575
           β†’ true
          This is because #mm or #to_mm etc. are methods that return an object of the Length class, not a Float. A Length is a Float that considers SketchUp's tolerance, which is currently set to 0.001 inch (we should never use this tolerance value directly since SketchUp might have the freedom to change it).
            Davidfi1
            so to find the length of I should use length.to_f ?
              To treat it as a float you must use to_f, yes. The numeric value of the objects are the same. The only difference of the Length which is a sub-class of Float is the comparison operators.
              ( [ 0,0,0 ].vector_to( [ 0,0,0 ] ) ).length.to_f < 0.01.mm
              That works because you're now dealing with the standard floating point comparisons. Not knowing what your experience with floating points are, but just in case; here's a very informative site on the topic: http://floating-point-gui.de/
                Davidfi1
                Very informative site in did.
                Thank you.
                I am a hardware engineer by training - so I know this problem from the other side
                and still it is a little strange πŸ˜„
