    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    Templar Town tour
    28 Posts 13 Posters 1.9k Views 13 Watching
    • AdamBA Offline
      AdamB
      @tandem said:
      Thank you Adam,
      I was not questioning LightUp requirements, I was mainly amazed how smooth your movement around the model was.
      I think there maybe something wrong with my system. I can't navigate the model this smoothly even without LightUp and with all plugins disabled. Every time I move all textures disappear until I stop.
      Here are my specs:
      3.2 GHz Intel Core i5
      32 GB 1600 MHz DDR3
      GeForce GT 755M 1024 MB
      OS X 10.9.3
      Yes, in regular SketchUp my laptop struggles and switches to wireframe etc, but in LightUp its fine.
      Your system specs look fine.
        Funny is to put any color lights and move after all the model in any positions from any pivot! โ˜€
        • TandemT Offline
          Tandem
          Very interesting. This just shows SketchUp's inability to take advantage of current hardware and highlights its lag in performance when compared to other software.
          • olisheaO Offline
            olishea
            We should do a kickstarter for sketchup and progress its development! ๐Ÿ˜†
            Sorry off-topic.
            How does LightUp handle product shots and close-ups Adam? Any good examples?
            oli
            • AdamBA Offline
              AdamB
              So LightUp is highly optimized and generally awesome - but don't confuse that with the needs of an Editor that needs to retain lots of additional information on the off chance you wish to edit stuff.. ๐Ÿ˜’
              I have no doubt that there are optimization opportunities in the SketchUp engine, but ultimately performance comes down to keeping the GPU busy - and many Components we use daily are composed of thousands of sub-components that could be edited and thus need to handle individually and will therefore be slower.
              Yep, using Image-based lighting gives great results for product shots - and its interactive.
              I'll post some example when I get back to the office next week.
              Adam
                ๐Ÿ˜‰
                • AdamBA Offline
                  AdamB
                  What is pretty cool about the video Pilou shared is its using LightUp support for Dynamic Components so you can include animated objects in your realtime rendering. In particular, its using an extended feature of LightUp DC support that allows objects to follow a Path around your model.
                  Setting the onClick behaviour of a Dynamic Component to:
                  animate("transformation", "name_of_path_group"),time=23.0
                  Would make your object follow the path specified by a Group called "name_of_path_group" and take 23 seconds to complete the path. The bus in the video is using this feature.
                  Adam
                    Little conceptual question in LightUp! ๐Ÿ˜„
                    Funny use of the Random Painter of Chris Fullmer!
                    And Protrude by Jim Foltz
                    So concentric Lights IES can have a random Color without effort! โ˜€
                    So cool storming colors on the ground. ๐Ÿ’š
                    But as Sun Light can't be used due erasing the colors' ground! ๐Ÿ˜ฎ
                    How have the shadows in direct? (without compositing images)
                    stormy_v7.skp
                    • 2 / 2
