    .get_element_value with radio button sets
    22 Posts 6 Posters 1.9k Views 6 Watching
    • sdmitchS Offline
      sdmitch
      Having never used html, I have resisted getting envolved with WebDialog but I have been working on a plugin that needs a user interface with multiple radio buttons. But I have run into a problem trying to get the value of the selected button using the .get_element_value function. Everything works as expected with a single radio button but, as soon as I add a second radio button, it fails to return the selected value and returns a null string instead. I searched the Plugins and Developer's forums but did find anyone else with this problem.
      Here is the basic code I'm using
      dialog = UI;;WebDialog.new
      dialog.set_file "c;/users/public/sketchup/plugins/sam.html"
      dialog.show
      dialog.add_action_callback("sdm") {|dialog, params|
      puts params
      var1 = dialog.get_element_value("align")
      var2 = dialog.get_element_value("space")
      puts var1, var2
      <body>
      <form action="skp;sdm@true">
      Align/Distribute Options;<hr />
      Align Objects;
      <br><input name="align" type="radio" value="Top-X" checked="checked" />Top-X
      <input name="align" type="radio" value="Ctr-X" />Ctr-X
      <br>Distribute Objects;
      <br><input type="radio" name="space" value="Lft-Z" checked="checked" />Lft-Z
      <br><input type="radio" name="space" value="Ctr-Z" checked="checked" />Ctr-Z
      <br><input type="submit" name="submit" value="Enter" />
      </form>
      </body>
      http://sdmitch.blogspot.com/
        You can add a hidden input field and hook up the onChange events for the radioboxes which updates the hidden field with the value you need.
          driven
          html1=<<SETHTML
          <!DOCTYPE html>
          <html lang="en">
          <head>
              <meta charset="utf-8">
              <title>
                SDMitch_test
              </title>
          <style> body {background-color; Window; color; WindowText; font; message-box; user-select; none; cursor; default; overflow; hidden}</style>
          </head>
          <body>
          Align Objects;
          </form>
          </body>
          </html>
          SETHTML
          html=(html1)
          dlg8 = UI;;WebDialog.new("it works again8",false,"img", 190, 180, 150, 150, false);
          dlg8.set_html(html)
          dlg8.show_modal
          dlg8.add_action_callback("sdm") {|dlg8, params|
          puts params
          var1 = dlg8.get_element_value("align")
          var2 = dlg8.get_element_value("space")
          returns html string to_s
          true?align=Top-X&space=Ctr-Z&submit=Enter true?align=Ctr-X&space=Lft-Z&submit=Enter
          edit to tidy up the html with css
          • Dan RathbunD Offline
            Dan Rathbun
            Sam,
            (1) Your setting both radio elements as checked, only one can be at a time, so the first (in the set,) is frivolous.
            (2) The WebDialog#get_element_value() method's dictionary text is misleading.
            The argument name is element_id, indicating that it is using the javascript function %(#8000BF)[getElementById()], but in text it says "get an element by name".
            In HTML the %(#8000BF)[id] attribute must be unique, but the %(#8000BF)[name] attribute does not need to be (and cannot be, in the case of radio button sets.)
            However, the %(#8000BF)[getElementById()] function (or the DOM,) would set the
            %(#8000BF)[name] attribute, to the %(#8000BF)[id] attribute, if you did not explicitly set the %(#8000BF)[name] attribute. (Or visa versa, it's been a long time, and I am still working on my 1st cup of coffee.)
            So the effect of calling %(#8000BF)[getElementById()]... it looks for an id match in the DOM's collection of ids, and if it does not find a match, then it uses the Js function %(#8000BF)[getElementsByTagName()], and returns the first (if the result array is not empty.)
            This "fallback" behavior may change depending on the standards mode, your %(#8000BF)[<!DOCTYPE>] tag sets.
            John's example sets the HTML in strict HTML5 mode ?
            In short... assign a unique %(#8000BF)[id] to each control element.
            πŸ’­
            I'm not here much anymore.
              Dan Rathbun
              The easiest way?
              Set the IDs for each button, but ONLY the value for the DEFAULT radio:
              html
              <br><input type="radio" name="space" id="Lft-Z" checked="checked" value="checked"  onchange="this.value=this.checked;"/>Lft-Z
              <br><input type="radio" name="space" id="Ctr-Z" onchange="this.value=this.checked;"/>Ctr-Z
              Now you retrieve the value, by unique ID.
              Also at MSDN... for input type=radio they show in the example that you can access the controls in the set by index .... (but this may be only in MSIE 8 Document mmode?)
              Like, Javascript:
              <script type="text/javascript">
              function detect_space()
                  if (space[0].checked)
                      // send a message to the ruby side
                  else if (space[1].checked)
                      // send a different message to the ruby side
              </script>
              • sdmitchS Offline
                sdmitch
                Thanks to all for your responses. I'm only a little more confused than before.
                I happened to find Chris Fullmer's "VerySimple" example that I think might be the solution to my problem.
                • Chris FullmerC Offline
                  Using anything of mine as an example in the webdialog world is probably a VERY bad idea. I am SO bad with webdialogs, html, etc.
                  Out of curiousity, what is my "VerySimple" example? I can't even think of what that was? 😳
                  All my Plugins I've written
                    Dan Rathbun
                    You likely would to put your HTML file within the specific plugin subdir, and give it a unique name (within that plugins names of dialog files, ie: "options.html"
                    So I changed the set_file argument to: File.join(File.dirname(__FILE__),'options.html')
                    Here is a Ruby-side example that should help debug things:
                    This assumes you set unique id for the radio buttons, as I suggested above.
                    module SDM
                      module SomePlugin
                        @@debug = true # set false when done debugging
                        class << self # anonymous singleton proxy class
                          def init_vars()
                            @dialog = nil
                            @align  = "top"
                            @space  = "left"
                          #  checkstate( value )
                          def checkstate(value)
                            if value == "true" || value == "checked"
                              return true
                            elsif value == "false" || value == "unchecked"
                              return false
                            return nil # default
                          end # checkstate()
                          #  options_dialog()
                          def options_dialog()
                            unless @dialog # Create dialog instance ONCE (nil evals to false)
                              @dialog = UI;;WebDialog.new("Options")
                              @dialog.set_file(File.join(File.dirname(__FILE__),'options.html')
                              @dialog.add_action_callback("sdm") {|dialog, params|
                                # user clicked "Enter" button
                                topX = dialog.get_element_value("Top-X")
                                ctrX = dialog.get_element_value("Ctr-X")
                                leftZ = dialog.get_element_value("Lft-Z")
                                ctrZ = dialog.get_element_value("Ctr-Z")
                                if checkstate(topX)
                                  @align = "top"
                                else
                                  @align = "center"
                                if checkstate(leftZ)
                                  @space = "left"
                                else
                                  @space = "center"
                                @dialog.close() # close the dialog
                                # debugging
                                if @@debug
                                  puts "Callback from options_dialog() returned;"
                                  puts "  User clicked the 'Enter' button."
                                  puts "  Returned params = '#{params}'"
                                  puts "  Element values after;"
                                  puts "    Top-X = #{topX.to_s}"
                                  puts "    Ctr-X = #{ctrX.to_s}"
                                  puts "    Lft-Z = #{leftZ.to_s}"
                                  puts "    Ctr-Z = #{ctrZ.to_s}"
                                  puts "  @var values after;"
                                  puts "    @align = #{@align}"
                                  puts "    @space = #{@space}"
                                  puts()
                              } # end callback
                            end # dialog creation
                            # show the options dialog if needed
                            if @dialog.visible?
                              @dialog.bring_to_front()
                            else
                              RUBY_PLATFORM =~ /(darwin)/ ? @dialog.show_modal() ; @dialog.show()
                            # debugging
                            if @@debug
                              puts "Method options_dialog() called;"
                              puts "  Element values before;"
                              puts "    Top-X = #{@dialog.get_element_value('Top-X').to_s}"
                              puts "    Ctr-X = #{@dialog.get_element_value('Ctr-X').to_s}"
                              puts "    Lft-Z = #{@dialog.get_element_value('Lft-Z').to_s}"
                              puts "    Ctr-Z = #{@dialog.get_element_value('Ctr-Z').to_s}"
                              puts "  @var values before;"
                              puts()
                          end # options_dialog()
                        end # proxy class
                        # define module methods here prefixed with self.
                        # RUN ONCE CODE
                        unless file_loaded?(File.basename(__FILE__))
                          init_vars()
                          # create menu item and/or toolbar command here
                          # whose execution proc is; { options_dialog() }
                          # register file as already loaded;
                          file_loaded(File.basename(__FILE__))
                      end # module SomePlugin
                    end # module SDM
                    • sdmitchS Offline
                      sdmitch
                      Sorry Mr. Fullmer, wrong Chris. It was an example by Chris Phillips.
                      Dan, thanks for the code. I believe the "verysimple" code is just what I needed but I'll keep yours just in case.
                        Dan Rathbun
                        Hey Chris you've got name recognition!
                        Found it http://sketchucation.com/forums/viewtopic.php?f=180&t=2606&p=12180&hilit=+very+simple+webdialog#p12180
                        That post is 5 years old. And it has some problems... the reference to the dialog is a local var of the method, and will go "out of scope" when the method returns. And the dialog will disappear (get garbage collected by Ruby.)
                        My example does much the same thing, but is written properly wrapped, using proper instance vars, and only creates ONE dialog instance, that is reused again.
                        The major difference is his immediately sends change notification back to the Ruby-side, without waiting for the user to confirm their changes by clicking "Enter".
                        What if they change their mind, and cancel the dialog instead, but after they have already changed a few controls ? They will expect that the changes should not take effect! .. and they really should not.
                        Anyway .. find some happy medium between the two. And enjoy!
                          Dan Rathbun
                          Reprise: Actually there are two kinds of WebDialogs that plugin authors create:
                          1. A standard options dialog that has an "OK" (sometimes named "Apply") button, along with a "Cancel" button.
                          This type does not apply the changes unless the user clicks the OK/Apply button.
                          1. A "toolwindow" style (aka "inspector",) dialog in which the control changes take immediate effect.
                          This type usually does not have buttons. The user closes the dialog when they are done by clicking the "X" button at the top-right of the window frame. Occasionally (if there is space,) a close button at the bottom of the dialog is provided. But most users would prefer such "toolwindows" to be as small as possible, as they will be floating open whilst they are working with the model.
                          The latter perhaps is what Chris Phillips actually wanted, which is why he wrote the Js function to immediately return the value changes to the Ruby-side.
                          So, Sam, you need to decide which of the two types you want for your plugin.
                          • sdmitchS Offline
                            sdmitch
                            Dan, Since it turned out simple enough to "decode" the parameters string, I did away with the "verysimple" approach and went the conventional update on submit.
                            When starting the plugin, the webdialog created has focus. Is there a way of giving the focus back to the model without having to click the wheel button?
                              Dan Rathbun
                              No current cross-platform method in the API. It has been requested, along with onFocus & onBlur observer callbacks.
                              Normally you could call in JS, %(#8000BF)[window.opener.focus()], but in the Microsoft WebBrowser Control interface, the %(#8000BF)[opener] window object is not exposed (presumably for security reasons?)
                              There is no API method that currently returns a handle to SketchUp's application window either, so you cannot have the html page tell the Ruby-side that the DOM loading is complete, and have the Ruby-side set focus back to the app. This has also been requested.
                              There are low-level solutions, on PC, using "Win32API.so", check the forum, ThomThom and I, and driven all discussed it. There's a topic labeled "Get Sketchup window handle" or similar.
                              • sdmitchS Offline
                                sdmitch
                                Dan, Just as I expected but not a big deal.
                                Thanks.
                                  driven
                                  Sam,
                                  T think you may want window_blur http://sketchucation.com/forums/viewtopic.php?f=180&t=49075&p=441642&hilit=.window_blur#p441398
                                  but maybe not...
                                  john
                                  • sdmitchS Offline
                                    sdmitch
                                    John, I tried the .show_modal and, just like the API said, nothing is allowed to happen as long as the WebDialog is displayed. I couldn't figure out how the hide it and then bring it back to make a change to the options selected.
                                      driven
                                      sorry sam, I'm on a laptop without access to all my test snippets so I pointed that one...
                                      the show_modal is for my mac, works with show on PC's
                                      these test are probably what I should have pointed to
                                      http://sketchucation.com/forums/viewtopic.php?f=180&t=49075&p=441642&hilit=.window_blur#p441326
                                      you can call focus or blur whenever you want, the dialog dosn't need to be focused to use them...
                                      1ohn
                                        Dan Rathbun
                                        @Sam:
                                        (1) It would help if you put your OS, and SketchUp Free vs Pro, into your profile, so it appears at the left of your posts.
                                        That way people would not purposely point you towards a method that was specific to an OS that your not developing on / for.
                                        (2) Have another look at the example I wrote for you. It does exactly what you just described. (And uses a platform conditional statement to call the correct show method.)
                                        Keep in mind you need to hold the option refs as @vars on the Ruby side, and restore them to the dialog's controls after each show (because the HTML file is reloaded.)
                                        Ie.. closing the dialog with close() does not destroy it. It is still a valid object, just as it was after you created it, but before it was shown for the first time.
                                        • jolranJ Offline
                                          jolran
                                          Hi!
                                          In John/driven's example he uses dlg8.set_html(html) with a Ruby "inline" HTML codestring. That works on Mac? I thought set_html() was to be avoided?
                                          So doing like that and putting in an image for button like below would work on Mac?
                                          In Ruby..
                                          my_icon=File.join(File.dirname(FILE), "folder/myicon_pic.png")
                                          ( In the HTML wrapped something like html = %[html + js code etc...])
                                          Have an image as a button:
                                          <img src="#{my_icon}" width="24" height="24" onClick="jsfunction()">
                                          Note, Im not using a separate Html file in this case.
                                          I think Adam is doing something similar in Goldilocks, but uses URL if I remember it correct.
                                          Hope I'm not hijacking the thread, thought it was relevant.
                                            driven
                                            Hi jolran,
                                            I agree, however there's a specific thread I started on the subject http://sketchucation.com/forums/viewtopic.php?f=180&t=49338#p443472
                                            try those test files on your mac... I have others as well, that work for me.
                                            john
                                            • 1 / 2
