    .get_element_value with radio button sets
    22 Posts 6 Posters 1.9k Views 6 Watching
      driven
      html1=<<SETHTML
      <!DOCTYPE html>
      <html lang="en">
      <head>
          <meta charset="utf-8">
          <title>
            SDMitch_test
          </title>
      <style> body {background-color; Window; color; WindowText; font; message-box; user-select; none; cursor; default; overflow; hidden}</style>
      </head>
      <body>
      <form action="skp;sdm@true">
      Align/Distribute Options;<hr />
      Align Objects;
      <br><input name="align" type="radio" value="Top-X" checked="checked" />Top-X
      <input name="align" type="radio" value="Ctr-X" />Ctr-X
      <br>Distribute Objects;
      <br><input type="radio" name="space" value="Lft-Z" checked="checked" />Lft-Z
      <br><input type="radio" name="space" value="Ctr-Z" checked="checked" />Ctr-Z
      <br><input type="submit" name="submit" value="Enter" />
      </form>
      </body>
      </html>
      SETHTML
      html=(html1)
      dlg8 = UI;;WebDialog.new("it works again8",false,"img", 190, 180, 150, 150, false);
      dlg8.set_html(html)
      dlg8.show_modal
      dlg8.add_action_callback("sdm") {|dlg8, params|
      puts params
      var1 = dlg8.get_element_value("align")
      var2 = dlg8.get_element_value("space")
      returns html string to_s
      true?align=Top-X&space=Ctr-Z&submit=Enter true?align=Ctr-X&space=Lft-Z&submit=Enter
      edit to tidy up the html with css
      • Dan RathbunD Offline
        Dan Rathbun
        Sam,
        (1) Your setting both radio elements as checked, only one can be at a time, so the first (in the set,) is frivolous.
        (2) The WebDialog#get_element_value() method's dictionary text is misleading.
        The argument name is element_id, indicating that it is using the javascript function %(#8000BF)[getElementById()], but in text it says "get an element by name".
        In HTML the %(#8000BF)[id] attribute must be unique, but the %(#8000BF)[name] attribute does not need to be (and cannot be, in the case of radio button sets.)
        However, the %(#8000BF)[getElementById()] function (or the DOM,) would set the
        %(#8000BF)[name] attribute, to the %(#8000BF)[id] attribute, if you did not explicitly set the %(#8000BF)[name] attribute. (Or visa versa, it's been a long time, and I am still working on my 1st cup of coffee.)
        So the effect of calling %(#8000BF)[getElementById()]... it looks for an id match in the DOM's collection of ids, and if it does not find a match, then it uses the Js function %(#8000BF)[getElementsByTagName()], and returns the first (if the result array is not empty.)
        This "fallback" behavior may change depending on the standards mode, your %(#8000BF)[<!DOCTYPE>] tag sets.
        John's example sets the HTML in strict HTML5 mode ?
        In short... assign a unique %(#8000BF)[id] to each control element.
        πŸ’­
        I'm not here much anymore.
          Dan Rathbun
          The easiest way?
          Set the IDs for each button, but ONLY the value for the DEFAULT radio:
          html
          <br><input type="radio" name="space" id="Lft-Z" checked="checked" value="checked"  onchange="this.value=this.checked;"/>Lft-Z
          <br><input type="radio" name="space" id="Ctr-Z" onchange="this.value=this.checked;"/>Ctr-Z
          Now you retrieve the value, by unique ID.
          Also at MSDN... for input type=radio they show in the example that you can access the controls in the set by index .... (but this may be only in MSIE 8 Document mmode?)
          Like, Javascript:
          <script type="text/javascript">
          function detect_space()
              if (space[0].checked)
                  // send a message to the ruby side
              else if (space[1].checked)
                  // send a different message to the ruby side
          </script>
          • sdmitchS Offline
            sdmitch
            Thanks to all for your responses. I'm only a little more confused than before.
            I happened to find Chris Fullmer's "VerySimple" example that I think might be the solution to my problem.
            http://sdmitch.blogspot.com/
            • Chris FullmerC Offline
              Using anything of mine as an example in the webdialog world is probably a VERY bad idea. I am SO bad with webdialogs, html, etc.
              Out of curiousity, what is my "VerySimple" example? I can't even think of what that was? 😳
                Dan Rathbun
                You likely would to put your HTML file within the specific plugin subdir, and give it a unique name (within that plugins names of dialog files, ie: "options.html"
                So I changed the set_file argument to: File.join(File.dirname(__FILE__),'options.html')
                Here is a Ruby-side example that should help debug things:
                This assumes you set unique id for the radio buttons, as I suggested above.
                module SDM
                  module SomePlugin
                    @@debug = true # set false when done debugging
                    class << self # anonymous singleton proxy class
                      def init_vars()
                        @dialog = nil
                        @align  = "top"
                        @space  = "left"
                      #  checkstate( value )
                      def checkstate(value)
                        if value == "true" || value == "checked"
                          return true
                        elsif value == "false" || value == "unchecked"
                          return false
                        return nil # default
                      end # checkstate()
                      #  options_dialog()
                      def options_dialog()
                        unless @dialog # Create dialog instance ONCE (nil evals to false)
                          @dialog = UI;;WebDialog.new("Options")
                          @dialog.set_file(File.join(File.dirname(__FILE__),'options.html')
                          @dialog.add_action_callback("sdm") {|dialog, params|
                            # user clicked "Enter" button
                            topX = dialog.get_element_value("Top-X")
                            ctrX = dialog.get_element_value("Ctr-X")
                            leftZ = dialog.get_element_value("Lft-Z")
                            ctrZ = dialog.get_element_value("Ctr-Z")
                            if checkstate(topX)
                              @align = "top"
                            else
                              @align = "center"
                            if checkstate(leftZ)
                              @space = "left"
                            else
                              @space = "center"
                            @dialog.close() # close the dialog
                            # debugging
                            if @@debug
                              puts "Callback from options_dialog() returned;"
                              puts "  User clicked the 'Enter' button."
                              puts "  Returned params = '#{params}'"
                              puts "  Element values after;"
                              puts "    Top-X = #{topX.to_s}"
                              puts "    Ctr-X = #{ctrX.to_s}"
                              puts "    Lft-Z = #{leftZ.to_s}"
                              puts "    Ctr-Z = #{ctrZ.to_s}"
                              puts "  @var values after;"
                              puts "    @align = #{@align}"
                              puts "    @space = #{@space}"
                              puts()
                          } # end callback
                        end # dialog creation
                        # show the options dialog if needed
                        if @dialog.visible?
                          @dialog.bring_to_front()
                        else
                          RUBY_PLATFORM =~ /(darwin)/ ? @dialog.show_modal() ; @dialog.show()
                        # debugging
                        if @@debug
                          puts "Method options_dialog() called;"
                          puts "  Element values before;"
                          puts "    Top-X = #{@dialog.get_element_value('Top-X').to_s}"
                          puts "    Ctr-X = #{@dialog.get_element_value('Ctr-X').to_s}"
                          puts "    Lft-Z = #{@dialog.get_element_value('Lft-Z').to_s}"
                          puts "    Ctr-Z = #{@dialog.get_element_value('Ctr-Z').to_s}"
                          puts "  @var values before;"
                          puts()
                      end # options_dialog()
                    end # proxy class
                    # define module methods here prefixed with self.
                    # RUN ONCE CODE
                    unless file_loaded?(File.basename(__FILE__))
                      init_vars()
                      # create menu item and/or toolbar command here
                      # whose execution proc is; { options_dialog() }
                      # register file as already loaded;
                      file_loaded(File.basename(__FILE__))
                  end # module SomePlugin
                end # module SDM
                • sdmitchS Offline
                  sdmitch
                  Sorry Mr. Fullmer, wrong Chris. It was an example by Chris Phillips.
                  Dan, thanks for the code. I believe the "verysimple" code is just what I needed but I'll keep yours just in case.
                    Dan Rathbun
                    Hey Chris you've got name recognition!
                    Found it http://sketchucation.com/forums/viewtopic.php?f=180&t=2606&p=12180&hilit=+very+simple+webdialog#p12180
                    That post is 5 years old. And it has some problems... the reference to the dialog is a local var of the method, and will go "out of scope" when the method returns. And the dialog will disappear (get garbage collected by Ruby.)
                    My example does much the same thing, but is written properly wrapped, using proper instance vars, and only creates ONE dialog instance, that is reused again.
                    The major difference is his immediately sends change notification back to the Ruby-side, without waiting for the user to confirm their changes by clicking "Enter".
                    What if they change their mind, and cancel the dialog instead, but after they have already changed a few controls ? They will expect that the changes should not take effect! .. and they really should not.
                    Anyway .. find some happy medium between the two. And enjoy!
                      Dan Rathbun
                      Reprise: Actually there are two kinds of WebDialogs that plugin authors create:
                      1. A standard options dialog that has an "OK" (sometimes named "Apply") button, along with a "Cancel" button.
                      This type does not apply the changes unless the user clicks the OK/Apply button.
                      1. A "toolwindow" style (aka "inspector",) dialog in which the control changes take immediate effect.
                      This type usually does not have buttons. The user closes the dialog when they are done by clicking the "X" button at the top-right of the window frame. Occasionally (if there is space,) a close button at the bottom of the dialog is provided. But most users would prefer such "toolwindows" to be as small as possible, as they will be floating open whilst they are working with the model.
                      The latter perhaps is what Chris Phillips actually wanted, which is why he wrote the Js function to immediately return the value changes to the Ruby-side.
                      So, Sam, you need to decide which of the two types you want for your plugin.
                      • sdmitchS Offline
                        sdmitch
                        Dan, Since it turned out simple enough to "decode" the parameters string, I did away with the "verysimple" approach and went the conventional update on submit.
                        When starting the plugin, the webdialog created has focus. Is there a way of giving the focus back to the model without having to click the wheel button?
                          Dan Rathbun
                          No current cross-platform method in the API. It has been requested, along with onFocus & onBlur observer callbacks.
                          Normally you could call in JS, %(#8000BF)[window.opener.focus()], but in the Microsoft WebBrowser Control interface, the %(#8000BF)[opener] window object is not exposed (presumably for security reasons?)
                          There is no API method that currently returns a handle to SketchUp's application window either, so you cannot have the html page tell the Ruby-side that the DOM loading is complete, and have the Ruby-side set focus back to the app. This has also been requested.
                          There are low-level solutions, on PC, using "Win32API.so", check the forum, ThomThom and I, and driven all discussed it. There's a topic labeled "Get Sketchup window handle" or similar.
                          • sdmitchS Offline
                            sdmitch
                            Dan, Just as I expected but not a big deal.
                            Thanks.
                              driven
                              Sam,
                              T think you may want window_blur http://sketchucation.com/forums/viewtopic.php?f=180&t=49075&p=441642&hilit=.window_blur#p441398
                              but maybe not...
                              • sdmitchS Offline
                                sdmitch
                                John, I tried the .show_modal and, just like the API said, nothing is allowed to happen as long as the WebDialog is displayed. I couldn't figure out how the hide it and then bring it back to make a change to the options selected.
                                  driven
                                  sorry sam, I'm on a laptop without access to all my test snippets so I pointed that one...
                                  the show_modal is for my mac, works with show on PC's
                                  these test are probably what I should have pointed to
                                  http://sketchucation.com/forums/viewtopic.php?f=180&t=49075&p=441642&hilit=.window_blur#p441326
                                  you can call focus or blur whenever you want, the dialog dosn't need to be focused to use them...
                                  1ohn
                                    Dan Rathbun
                                    @Sam:
                                    (1) It would help if you put your OS, and SketchUp Free vs Pro, into your profile, so it appears at the left of your posts.
                                    That way people would not purposely point you towards a method that was specific to an OS that your not developing on / for.
                                    (2) Have another look at the example I wrote for you. It does exactly what you just described. (And uses a platform conditional statement to call the correct show method.)
                                    Keep in mind you need to hold the option refs as @vars on the Ruby side, and restore them to the dialog's controls after each show (because the HTML file is reloaded.)
                                    Ie.. closing the dialog with close() does not destroy it. It is still a valid object, just as it was after you created it, but before it was shown for the first time.
                                    • jolranJ Offline
                                      jolran
                                      Hi!
                                      In John/driven's example he uses dlg8.set_html(html) with a Ruby "inline" HTML codestring. That works on Mac? I thought set_html() was to be avoided?
                                      So doing like that and putting in an image for button like below would work on Mac?
                                      In Ruby..
                                      my_icon=File.join(File.dirname(FILE), "folder/myicon_pic.png")
                                      ( In the HTML wrapped something like html = %[html + js code etc...])
                                      Have an image as a button:
                                      <img src="#{my_icon}" width="24" height="24" onClick="jsfunction()">
                                      Note, Im not using a separate Html file in this case.
                                      I think Adam is doing something similar in Goldilocks, but uses URL if I remember it correct.
                                      Hope I'm not hijacking the thread, thought it was relevant.
                                        driven
                                        Hi jolran,
                                        I agree, however there's a specific thread I started on the subject http://sketchucation.com/forums/viewtopic.php?f=180&t=49338#p443472
                                        try those test files on your mac... I have others as well, that work for me.
                                          It used to work, then it didn't. Then it might be working for some. But not me.
                                          I wouldn't rely on it.
                                          • jolranJ Offline
                                            jolran
                                            Ahh, I see John. If I get it right the sethtml thing is working cause of updated Mountain Lion?
                                            Thomthom, I have been searching through threads where you discuss just this issue, thats why I also asked this question. Being not confident in Webdialog, the platform issues are a bit confusing sometimes. But I take your word for it and try to fix it with set_file instead.
                                            Thanks.
