    Post_url returned data
    12 Posts 3 Posters 985 Views 3 Watching
    • alexschreyerA Offline
      alexschreyer Extension Creator
      Hi All,
      Does anyone know of a way to capture returned data from a post_url operation? This is something I came across in my Sketchfab uploader plugin and I can't figure out how to get around it. In short:
      I send some JSON data to an API via post_url:
      dlg.post_url("https://api.sketchfab.com/model","somedata")
      This prompts some returned data like the following, which I would like to capture for display:
      {"success": false, "error": "bad api call"}
      Since post_url doesn't return anything, I get on Windows IE trying to save a download and on the Mac this string replacing my WebDialog's content. Would be so much better if I could assign the post-url result to a variable.
      Cheers,
      Alex
      Author of "Architectural Design with SketchUp":
      http://sketchupfordesign.com/
      • Dan RathbunD Offline
        Dan Rathbun
        You might check out the standard Ruby libraries CGI and those classes wrapped in Net that begin with HTTP... (such as Net::HTTPResponce)
        BTW .. did you use UI::WebDialog#allow_actions_from_host() ?
        I'm not here much anymore.
          Is there an easy way to call the Net functions without having full Ruby installed? I thought that was a requirement. Would be best if I could use them, though.
          It doesn't seem to make any difference in functionality if I use allow_actions_from_host...
          Cheers,
          Alex
            Jim
            You can do a POST request using an XmlHttpRequest object from inside your webdialog.
            Or if you are using jQuery, use jQuery.post()
              I tried Ajax via jquery before. The problem was that I was moving a lot of data (a base64 encoded model) from Ruby to jQuery and somehow even the Ajax post function in jquery would only send the request as a get request. In any case, I wanted to keep the data on the ruby side and sending it using post_url makes sense for efficiency but unfortunately the function doesn't know what to do with the returned data.
              I already filed a FR for this but I thought you guys had an alternative method.
              Cheers,
              Alex
                Dan Rathbun
                I would not recommend it. Some day all SU users will have a full Ruby install. (fingers crossed)
                Search this forum for XMLHTTPRequest
                It has been discussed, but I never had a reason to use it.
                Somehow the Google sites send data back to WebDialogs.
                  I am all for that!!!
                  Cheers and thanks!
                  Alex
                    Dan Rathbun
                    (http://api.jquery.com/load/)":a6sasixz]
                    The POST method is used if data is provided as an object; otherwise, GET is assumed.
                    ... and ...
                    Due to browser security restrictions, most "Ajax" requests are subject to the same origin policy; the request can not successfully retrieve data from a different domain, subdomain, or protocol.
                    So be sure you create a Javascript Object holding your data, not a simple String or Array.
                      Yes, I had been trying/fighting with the same origin thing on this and I believe my problem here was that I was requesting data from a different server. This required me to do this as a JSON/JSONP request, which I could only send as a string, hence the resulting GET request for the POST AJAX function in jQuery. Catch-22...
                      Cheers,
                      Alex
                        Jim
                        Ah, so maybe you need to get sketchfab to serve up the contents of the webdialog in order to use jQuery .post()?
                          Dan Rathbun
                          (http://api.jquery.com/load/)":w6xqf2o1]...
                          Working with client-side browser extensions lately... and found a link to this article within the Google Chrome Extension Developer's Documentation, on the Content Security Policy page.
                          **, of Google Developer Relations, at html5rocks.com in Tutorial: AN INTRODUCTION TO CONTENT SECURITY POLICY":w6xqf2o1]
                          Content Security Policy 1.0 is a W3C Candidate Recommendation, and browser vendors are expected to rapidly adopt the standard. That said, the W3C’s Web Application Security Working Group isn’t lounging around, patting itself on the back; work has already begun on the specification’s next iteration. Content Security Policy 1.1’s Editors’ Draft is under active development.
                          Client-side browser extensions like Chrome's, put the " content_security_policy" key & value string, within the extension's manifest object, saved as a manifest.json file.
                          Server's will begin using HTTP Responce Headers (as described in the article,) and later perhaps as %(#8000BF)[<META>] elements in the %(#8000BF)[<HEAD>] of a web document.
                          Chrome experimentaly already allows the %(#8000BF)[<meta http-equiv="X-WebKit-CSP" content="[POLICY STRING GOES HERE]">] tag.
                          MSIE as usual, is behind the rest of the browser world.
                            Dan Rathbun
                            @Alex: I see Sketchfab has a page with your plugin, ...
                            Did you solve this issue ??
                            I did find this page that has interesting reading, although the samples use GET.
                            Cross-Origin XMLHttpRequest
                            So I wonder if this might work when "allow actions from host" were true?
